What do you guys think of using Amsoil?
Used amsoil in my harley electra glide. It ran alot cooler, trans same way and shifted better. But like any thing else it is in what you like. Going to amsoil on up coming oil change.
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I know some will state apples and oranges. I can only comment on the Dominator 2 stroke oil. I use that for my Yamaha Banshee's. Many dirtbike buddies, that have rebuilt engines that have used Amsoil, and engines that used other brands, say the proof is there. It does protect the walls better.
Have used AMSOIL in all of my vehicles since 99 and am very satisfied with the lubricants' performance. I can tell you that it (Severe Gear 75W90) was the only gear lube that solved the diff chatter in my 99 coupe AND did the same thing for my 06. Since I first started using AMSOIL in my vettes, I have noticed slight increase in oil pressure and cooler engine temps, smoother shifts at all points in the AT using their ATF, and a quiet diff. I change my oil every 5k miles and notice better viscosity and lighter color (less break-down) in the AMSOIL 5W30 during drainage, than other products that I have used for the same life cycle and driving conditions. "Subdriver" can really fill you in with data and customer observations. He is the AMSOIL guru.
Spend your $$$ and put your faith wherever you want to but in AMSOIL I trust. Is it necessary?? No, but it is what I choose to use. JMHO.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
It appears to be a quality lubricant. However, it is not certified as recognized by GM and in the event of a significant warranty claim (lilke engine failure) its use could invalidate the factory warranty. Of course, if your car is out of warranty.....
I previously researched this thoroughly, after getting an oil change at ECS (it's all they use and recommend, which speaks well of the product.) But after posting the topic on this forum, and reading up on the subject - I soon replaced it with Mobil 1. Again, I believe its a quality product, but I chose a course of action that would not involve a debate with GM over my warranty in the event of an unforseen problem. Maybe that I'm over cautious, but I'll wait until my warranty expires before using it.
NCM Lifetime Member
#33
1 Post
The Amsoil XL and OE series are certified and or the equivalent of Mobil 1. The Amsoil EXTENDED drain series are not certified but are a higher end oil then Mobil 1. Amsoil has lots of products. Slower sellers due to cost are not certified. But the oil that is recommended for your Corvette is.
#36
I use amsoil products in everything I own, from diesel trucks to the corvette. But I also get a great deal on there products. If I had to pay retail I probably wouldnt.
#37
Get Some!
#38
Would used 5w30 produce less than 0w30 new oil? Its definitely possible, as Ive seen that type of change result in 2-3hp gain on a 150hp bike motor.
#39
I just got an email from an AMSOIL dealer and office colleague transmitting a bulletin published March 29th to dealers that AMSOIL's top tier (25k drain interval) ASL product meets and exceeds GM's new dexos1 spec in the 5W-30 viscosity grade. AMSOIL had sent me an email last fall answering a direct question I had for them regarding dexos1. They advised that 1st quarter of 2011 would be the timetable for reformulating their top tier motor oils to meet dexos1. They have now done what they said.
#40
I've heard adding a couple quarts of their 75W-140 gear lube to the engine really increases oil pressure. You might want to try that.
