Combining GY and Firestone runflats?
The front tires on my 2009 vert (GY runflats) are worn out and need replacing. I will replace them with Firestone Wide Ovals. Did the same on my 2006 vert, loved the Firestones grip.
But,
my rear tires are fine (GY) so i do not need to replace them, so the question is, will i have issues of any type by replacing the fronts with Firestone and leaving the original GY's? Or should i just replace them all?
But,
But,
But,
if the rears dont need replaced and you dont want to or dont have the money to replace all 4 then dont. youll be fine as long as you replace fronts with a tires that are same diameter you wont have any probs. i had firestones on all four corners then replaced rears with hankooks and ran the rf's upfront for months. there are alota cars on the road that have 4 different tires. i wouldnt recommend it but as long as they are all sized properly you wont do any damage to car or throw off speedo.
Received 2,047 Likes
St. Jude Donor '13
Having different brands of tires front & rear may work out just fine, or not. Usually, the handling differences show up as you approach the cornering limits of the car in an emergency or in enthusiastic driving. The results can be surprising.
Even though your rear tires are in good shape, they will have less tread on them than the new Firestones up front. And the Goodyears ain't known for their wet weather grip even when new. Again, it could work out fine (especially if you don't drive in rain), or it could bite you in the butt.
You choice. Be careful.
But,
But,
Is t here a problem with mixing these two different types of tires together?
Received 8,924 Likes
Although the GY slips some when the road is wet/damp it does quite well in deep water. Depending on which Firestone you are getting it will probably be even better. The Firestone SZ50 and Wide Oval tires are outstanding in deep water.
There are a lot of people who drive cars with mixed tires with no issues but it only takes that one emergency that wouldn't have ended in a mishap if the tires would have all been the same.
Bill
Good decision, IMHO. If you amortize the cost of tires over their life they are really pretty inexpensive for what you are getting though the upfront cost can seem high.
I have GY runflats (OEM) on the front, but put on a set of NITTO Drag Radials on the rear...
I have to drive 100 miles each way to & from the track.. "Never had a problem on the Garden State Parkway at 75 mph or on the curvy Saw Mill Parkway up her in Westchester....
My only problem is if I get caught in rain, then I just SLOW DOWN to 45 - 50 mph and stay in the right lane...
