AC making loud noise
I live in FL and it's extremely hot down here. Especially when I get in my black c6 coupe after work. I was driving home yesterday with the A/C on, and all of a sudden the air got loud, like this loud buzzing sound. I'm not talking about it getting loud because the A/C was on max. It's this loud buzzing kind of a humming sound. I plan on taking it to the dealer, as it's a certified preowned vette that came with a 12 month/12,000 mile bumper to bumper warranty. So I'm assuming this will be covered. I was just curious if anyone else has had a similar experience. Thanks!
i also have the humming/moaning sound/feel on my clutch pedal with the a/c on. been over a year, since it still blows cold air. too scared of $ to have dealer take a look at it. let me know what they fix on yours
Just took my 05 in due to ac problems. Had to replace temperture contol head unit, condenser, actuator motor and another part that controls the air direction. Total cost $2,800. Good thing I purchased an extended warranty. My cost was $250.
the same thing happened to me a long time ago the buzzing or humming noise is the cowl for some reason it warps and the noise will drive you crazy...put a piece of 2" masking tape on the top of the cowl and windshield go for a ride if the noise stops ...presto you problem solved good luck mine would do it at highway speeds
This should be covered under the 12 month/12,000 mile bumper to bumper warranty I got with the car because it's certified pre-owned, right? I took it in because the top was crazing, not thinking they would replace that, but they did with no questions asked. I was shocked I got a new glass top under that warranty.
Does the noise get quieter if you turn the blower speed down & louder when turned up? I had this happen...had a napkin, from the glove box, get sucked into the fan.
Let us know what the sound was.
Yes, leave (napkin - like above) could have entered the box and is makeing a noise. Was a common C5 issue. In C5 one removed the box cover under the passenger dash for access...fairly easy to do. You could try removing the cabin filter and vacuuming as a quick attempt at fixing if it is this issue.
IF I take everything out of my glove box and the cabin filter should I be able to find the problem, if it was in fact a napkin that got stuck?
Thanks!
I took my Vette in to have the A/C servuced and oil change. The technician was not very careful, he scratched and scarred my seats in several places. I've emailed service manager but have not heard back. What do you suggest?
Thanks,
Laura
GM Customer Service
Thanks,
Laura
GM Customer Service
PUNISHERC6,
If you are unable to resolve your concern, feel free to reach out to me or Evan. We would be happy to look into this for you. You can contact me via email at well at tricia_marie@gmexpert.com. Thank you.
Tricia, Chevrolet Customer Service (Assisting Evan).
William R.
Chevrolet Customer Care
