fob slot near glovebox
Went to start my 06 last and got the "no fob detected" message. Used the other fob and all went well, so it's probably time to change the fob battteries as these are the original ones.
But then, as an experiment I put the failed fob in the fob slot near the glove compartment and the car started normally, which is good to know. And this leads to my question. What is it about the fob slot that lets it overcome a low fob battery? Is it closer to the fob signal receiver or something more mechanical in nature? Anybody know?
I've not used the slot but just like my wifes BMW Z4, the slot provides car battery power to the FOB? I must say though, I don't know where the physical battery contacts are on the FOB?
Just speculating.....
Moderator
Received 3,578 Likes
Inductance. That is how the fob is read in the glove box slot.
I think I've got it. The car's battery power system, (through an iductive device), induces enough voltage into the fob's circuitry for it to function. Makes sense and relatively simple.
As always thanks for the education.
Some C6s will actually work without any battery in the fob at all...mine is that way and a few people on here have tested theirs and had them work also. It is not something to be expected though...it does not work on all, just some.
When changing the battery in the fob, does the fob have to be re-programmed or are you good to go with just the battery change ?
My fobs are a little over 4 yrs old and I was thinking of changing the batteries before they fail.
No, no programming necessary.
You would use the key to open the rear hatch/trunk then use the emergency door release at the left rear wheel well to open the driver's door.
Probably a good idea. Stay away from the Ray-O-Vac batteries with the rough surface on the + side of the battery. Folks here who bought these say the battery contact with the fob is intermittent.
As Rick said above, no programming necessary and this is because it is the car that is actually being programmed to recognize each of the fobs...the fobs are not being programmed themselves.
I didn't want to make a new thread on this, sorry to dig up this old thread but I didn't realize have the key with the fob either attached or hidden somewhere is probably a smart idea in case the fob battery ever goes out so you can access the trunk for the door latch. I've been cruising around without my key as it's nice in the pocket with just the fob and I don't really trust hiding a key somewhere on the exterior of the vehicle plus with the convertible top down I don't worry about it as I can lean in car, but as weather starts cooling down and top up I probably should start carrying the key with me attached to the fob or find a spot to hide it.
https://www.corvetteforum.com/forums...key-blank.html
Iceman007 (09-29-2016)
