How many of you guys have had this issue? a/c compressor whine (video)
My car has been doing this for a few weeks, and has gotten worse over the last few days. After some searching, it seems to be a fairly common issue.
When it is really hot out, and the car has been sitting in the heat. If I rev the engine to about 2500-3000 rpms, and let off, it makes this wierd grinding, whizzing noise at about 1700-1800 rpms. You can here it and feel it in the clutch pedal as you shift as well.
It would appear that it is the a/c compressor bearings going bad, and several people have had theirs fixed via warranty. Mine is out of warranty!!
I'm just curious as to how common it actually is!
This guy made a video of his car making the same sound:
http://www.youtube.com/watch?v=3GAbiUcDyRg
Here's mine doing it...
http://www.youtube.com/watch?v=x69CKRFahDI
Please post a reply if you've had this problem!!!!!
Not sure how common it is, but my 2007 Z06 with 13,500 miles on it started making the same exact noise a couple of weeks back. Fortunately I have an extended bumper to bumper warranty through next month.
I also had an oil leak (turned out to be power steering fluid) so I took it in for both items. They replaced the power steering reservoir and the idler/belt-tentioner, saying that they thought it was making the noise. It wasn't the idler, but they thought they might try that first.
Now they have the a/c compressor on order (said it would be two weeks). Not a huge deal as I have my car back and the a/c works great for now.
So anyway if I had just the normal 3 year / 36K mile warranty, I would be paying for this myself ... and NOT very happy with under 14K miles on the clock.
Sorry that you are having the same issue without warranty help. How many miles do you have on your Corvette?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Just tell everyone that's your 371 whining....
My 2005 MN6 with 48K is behaving exactly like this. Just started a couple months ago.
It is actually the A/C bearing making the noise or could it be the A/C clutch? You're winding up the motor then backing out of the throttle. Could it be the A/C clutch slipping because the compressor wants to remain spinning faster than the engine?
The compressor looks to be $350 + shipping (about $430 total). Any idea how much labor is involved in the Replacement?
Can we truly just live with this "annoyance"?
I've read some post which state that the engine cradle has to be dropped to get to it. Also, the dryer is part of the condenser, so the condenser would need replacing as well...
FUN!!!
FUN!!!
That would bite, another $300 + labor. So the evaporator needs to be changed out with the compressor?
Mine does it
My 2007 has been doing it for about the last 15k miles. My car currently has about 52k miles on it. The noise/vibration hasn't gotten any worse during that time and the a/c still blows ice cold. I've had my a/c gauges on it and it all reads as expected. Frankly, I'm not going to worry about it anymore. We are on about day 45 of over 100 degree days here in Austin and the a/c is keeping me nice and cool.
I looked on ebay, and you can buy a "kit" that comes with the compressor and condensor, with a 1 year warranty for $599. Then there is labor and the cost of freon of course. I would do my own work, but would still have to take it in to have the system evacuated and charged. A shop normally charges about $125-150 for that, making this a minimum $750 job...
Had that 2 summers ago on my '05, fixed on my extended warranty, replaced compressor.
Anyone have the procedure for removing the A/C belt? I'd like to perform that experiment. I have another noise I've been monitoring that "sounds" like a bearing type of noise and "hoping" it's related.
1 Post
I have the same problem. On my 2009 Zo6, It started about 2 weeks ago. I am going to the dealer today. The utube help me.
thank you,
ed
Mine replaced under warranty
Mine started doing it last summer on my 2009 Coupe. I had it replaced under warranty. According to the work order there was a screw that had either backed out or was not properly seated in the clutch assembly on the compressor. In my case the compressor eventually stopped working.
