Controlled Burn-out with A6
Supporting Vendor
Unbelievable! All you have to do is, put your car in Competetive Mode, pump your brakes 3 times & hold hem down, put your car in "S" mode & throttle it up to 4000 plus RPM. The rear tires WILL break loose. When the RPM starts to drop, let off of the brakes and you will have accomplished a "burnout". It ain't rocket science.
By the way, I've run my car over 150 times & I do not have a line lock. However, to do the same thing in a M6...you need one.
Here was my 5.0 6 speed manual car at the track last year.
http://www.youtube.com/watch?v=DnEyIys8ogE
Supporting Vendor
You dont need one in a manual car to do a burnout at all. You can either do it the dumb way and dump the clutch and the hit the brake and do the burnout. Or, you can use your right foot on the brake and throttle, and your left on the clutch. You would think i had an auto when i do a burnout with a stick car, it wont even move.
Received 2,061 Likes
Just a bolt-on LS3 and a crappy night video, but you get the idea it can be done with less power than Christopher's cammed LS7 powered A6.
It's not a Utube, so you need to click on the pic. Hopefully someone can tell me how to do this without all the excess stuff.
Go Canes!
