Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- Corvette Jack Up Your Vette How to
Step by step instructions for do-it-yourselfers.
Need to jack up my C6 to do a brake job
#41
Thanks Berk4422 !
Where did you get your Crossbeam Adapter for your jack. It looks like the perfect length. I looked at the ones at Harbor Freight today and they seem way too long at 28" to 37". Their's also have a threaded stud that screws into their floor jacks. My 3-ton floor jack is set up for a 30mm stud.
Thanks!
Thanks!
#43
Still looking for a Cross Beam adapter for my floor jack. I pick up my new toy today and will certainly want to jack it up this weekend to check brakes, detail rims, etc.
My current 3-ton jack lift pad has a 30mm stud that fits in the lift beam of the jack. Any ideas???
#45
#46
Received 2,093 Likes
#47
Thanks! I checked out the Harbor Freight Cross Beam and saw that it was not only too long but it attached to the jack arm with a fairly short bolt instead of a shaft like many jack lifting pads use. I'm assuming that you both have the Pittsburgh floor jack that uses that type of attachment?
#48
#50
How did you guys attach the lifting pads to your cut-down beam? The one at my Harbor Freight had threaded inserts welded into the movable arms. Also, were you able to find a length that works for the front and rear jacking points ?
Thanks again
#51
Did my brakes -- calipers, lines, pads -- this winter and jacked it up as you describe -- front and back.
However, I needed the pucks to place the jackstands. I guess I could have used the jackstands on the cross members, but that is where I was jacking from, so that's a problem. Plus, I wanted the stands out wider for stability.
You can certainly do one wheel at a time, but much easier if all four are up, especially if you need to bleed the system. JMHO
#52
AeroJim, go to https://www.ecstuning.com/
$170 --- It is on sale too saving you $30. Schwaben Long Low Profile - High Lift Floor Jack. I think this is the same as Arcan XL2T. Mfg Part # 029121SCH01A ECS Part # ES#3982295
Min Height: 2-3/4"
Max Height: 24"
Handle Length: 49-1/4"
Jack Body 35" in Length
Saddle Diameter: 4" with full saddle pad
ANSI / ASME PALD 2009 Certified
4000 lb Capacity
$85 for 2 --- Wide base 3 ton professional jack stands tall. Mfg Part # 029376SCH01A ECS Part # ES#4017319
Schwaben 3 Ton each ( 6000 lbs)
Stable flat top with a rubber cushion to prevent damage to bottom of car.
Pad is 4-3/8" in diameter and is a tight fit to stand.
7/16" x 3" ball locking pin for safe yet quick disconnect. Secured to stand with chain.
9 adjustable Heights Min 13-1/2" to Max 22"
Stable boxed arms with 1-1/8" center shaft
Three 3-1/4" round base feet for maximum stability .
Min Height: 2-3/4"
Max Height: 24"
4000 lb Capacity
