Flashing Temperature on HVAC Climate Control Unit
1 Post
Hey guys I was wondering if anybody knew how to fix the problem when the climate control starts flashing and does not work in our c6's? I know everyone says its dying and you need to buy a new unit but I was wondering if anybody was actually able to fix this themselves. I think it could be something as easy as loose solder joints. Please chime in if you have any information or have fixed a unit yourself. Thanks
Here is a quick video I took of the problem:
http://www.youtube.com/watch?v=ky3Aum09mSY
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,819 Likes
2015 C7 of the Year Finalist
Head unit is croaking. Needs to be replaced.
Elmer
Elmer
jb_va2001 (07-31-2017)
My 04 4Runner had the same problem. It was the compressor clutch relay. $75.00 for the Toyota-branded relay and the A/C is perfect. Do some research on Google for vehicles with same problem.
I got the same problem now in my 08 Z06 w/ the flashing. Working on a solution for it.
Took it to the dealer and they obtained some disk to reflash or reprogram everything and after 2 days it was back to normal--no replacement. I think there's TSB on it. If your dealer doesn't have it PM me and I'll search my records.
Just had the same problem when I took it out of storage in March. First day the display started flashing and the next day the flashing stopped but the radio and NAV didn't work.
Yeah, mine's an 08 with about 50k... I am thinking about taking it to the dealer for their trouble code analysis. And if they say it's the head unit, wait until it goes out all together, and replace it myself. The part is only about $300 online.
I just don't want to drive it like this if it could be harming the compressor, etc... Thanks.
There is a reset procedure that you might want to try, press the first two buttons on the right and the fan speed up buttons on the AC control at the same time. It updates the temperature readout not sure what else it does.
This isnt like the trick where you press ALT+F4 to make a bookmark? haha.
Mine did this on and off for over a year. would be fine, then do it, then be fine. Replaced it with a used unit, no issues so far.
mitco39 (09-03-2016)
2005, adjustment, blinking, c5, c6, climate, control, corvette, electronic, flashing, hvac, temp, temperature, temperture, z06
