coolant additive to lower temp
2 bottles of WaterWetter in the Vette lowered temps 5-10 degrees. 1 bottle in the John Deere lowered temps 10 full degrees. Both use antifreeze.
Those that ALWAYS say save your money or Don't do it, have most likely never tried it. Won't hurt a darn thing.
Tolero Apto Victum
Good stuff. I use that in my 07 Vet, which has over 120,000 miles on it. So far so good, it is good for corrosion prevention as well.
I may try the same. My 05 can easily reach 220 or 225 when pulling a hill. Today the abmient temp was 101 and the coolant temp hit 232 when pulling a hill at 35 mph. It did come back down quickly once off the grade however.
Tolero Apto Victum
I'm resurrecting the old thread. I've now seen tested #'s showing that although these water wetter products DO slightly reduce temps even with normal 50/50 antifreeze /water blends, that they DO cool better with just distilled water. A nice middle ground, if you live in a moderate climate like me in Seattle- is to use only 20% antifreeze and 80% distilled water and then your water wetter additive.
Should be closer still to water only and water + water wetter temps.
Adam
Adam
#36
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
What I said on post #9 of this thread from 5 years ago ....
Water Wetter was designed to be most effective when used with straight water (as used in drag racing competition cars).
Adding it to the normal coolant mix we have in our C6s is pretty much a waste of money and does very little to lower coolant temps.
