rattles and noise from roof
what do you use to lube the rubber weather stripping on removable roof. my roof my makes so much nosie whenever i go over bumps or turns and the body flexes.
Received 2,049 Likes
St. Jude Donor '13
There is a GM bulletin about 8 pages long (!) on fixing roof noise. If you are under warranty and just using some dielectric silicone grease doesn't solve the problem, get the bulletin and work through it yourself or have your dealer do it under warranty.
Under warranty, my top had 4 different issues that needed to be corrected. Now, it's perfectly quiet.
I used Super Lube ($6 from Ace Hardware), some clean rags & Q-tips. Put the top on soft blankets & carpet for easy access.
Be sure to read this:
http://forums.corvetteforum.com/c6-c...long-post.html
Hopefully the lube will fix your noisy roof. If not, the above thread has other possible solutions.
Just don't over-lube it -- too much makes a mess:
http://forums.corvetteforum.com/c6-c...ships-fix.html
http://www.z3bimmer.com/OffTopic/E24...s/gummi_02.jpg
Do a google search for a number of sources......also, Amazon sells it.
It's made for rubber to lubricate and protect.
