Why does my battery go dead when it sits for 2 weeks
How long will a battery last if it's on a tender?
I started mine on a tender about a year into ownership. The battery has never needed a jump. Mine's an A6 '06. How much longer can I expect the battery to last?
I don't know for sure but my guess is because it resulted in many drained batteries and pi$$ed off people so they changed the design. Also there was a programing problem that year that when even in reverse the battery would drain. They came up with a reflash for the computer for that problem.
Like "cape" says, once a batteries been run down to total zero, it's usually a goner, and probably why your car wont even make it two weeks sitting. These cars have lot's of electronics that slowly discharge the battery when sitting idle. Sounds like your car's still within the original 36mo/36K mi warranty, so have the dealer check it, as you may be getting a free Delco Pro. Also some mention earlier of an 06' with the original battery. Just replace it for $100 buck's, as not worth the trouble. I'm also a big Ctek 3300 fan, as have two rotating around on all kinds of stuff here.
It's the stupid FOB system that drains the batt, again, I'd rather have a normal key, but that's MHO. And if you wired the M2W switch wrong that will drain it, like a boss ...
This is second time it happened to me, the battery going dead after sitting for 2 weeks. I know i need to drive it more but i have never had this problem with other Corvettes. Its a 2010 Grand Sport Manual trans car with 3900 miles. I guess its off to the dealer to have it checked
1) You may not be driving it enough to fully charge the battery, when you do drive it, so you should keep a charger on it.
2) As someone said above, once a lead-acid battery goes dead once, it's essentially shot. Replace it.
I have left mine as long as 3 weeks (once) with no issues, but it's my daily driver so it's always well charged.
1 Post
The C6 (and all other modern cars) have lots of little embedded computers in them that never turn completely off, they only enter a low-power "sleep" mode where they draw very little current. However, because they do draw current, a C6 can only sit for about 3-4 weeks - and that's only if the battery was fully charged prior to parking it. If the battery was not fully charged, or the battery is weak, then you can expect even less time. This is normal behavior and does not indicate anything is wrong with your car (except for the weak battery case, of course).
As the other posters have said, a battery tender is a must-have if your C6 is even a partial a garage queen.
I have an 06 and it sat for more than two months without being touched and fired right up. Battery was replaced right before I purchased the car in october of last year.
I had to have a new Delco for my '09 less than year ago. I took the original in and it Failed. No charge to me, warranty.
Ask the dealer or use a multimeter to check your cars milli-amp draw. Our car pulls 18-20 Ma as an example. To much draw and it will drain your battery quick. Good luck.
#33
#34
Vette Nut – please keep us updated on what happens at the dealership. If you have any other questions or concerns, please send me a private message.
Thanks,
Laura
GM Customer Service
Thanks,
Laura
GM Customer Service
#38
