rubbing noise right front tire
This morning on my way to my daily breakfast run i heard a rubbing noise coming the right side, after i got back home jack up right side turned the wheels noise was coming from front wheel, took the tire off to find the top caliper bolt was missing and the caliper was rubbing the wheel, went auto zone got replacements clean everything up. Now the old saying is if you got lemons (wheels off) make lemonade (repainted my calipers) its was a good day
Glad you quickly remedied it and all is okay - things happen and happy nothing got damaged!
Thanks,Matt
Thanks,Matt
Maybe a little loctite on the bolt threads would stop this from ever happening again...They make a blue Loctite that stops bolts from moving but is easy to get the bolt out with a socket or wrench, this is what I use....WW
