service active handling
I received the service active handling error and it disabled itself. I normally drive in competitive driving mode took it up to the dealer and we put the tech II on it and it said there was a communication issue between the EBMC and the Cluster. Has anyone seen this issue I have it up at the dealer now. Funny thing is this is the first time I have seen this since the build and it did not happen till after the alignment (which i think is unrelated) but after a restart and driving about 2 miles it comes up with the error. Its a 2010 Grand Sport
John
John
You can do a search on this subject and see that there is a lot to read. My similar experience resulted in the EBCM needing replacement. Further similar issues were solved by treating all computer connections with dielectric grease. My car has been glitch free for over 2 years. Good luck.
Received 8,926 Likes
John
John
The EBCM resets with each restart so some of the codes are reset as well. Did the mechanic take the car out for a ride with the Tech II hooked up to see what code was set when the message was displayed after the two mile drive? I suspect the message had something to do with the steering not centering which could be a steering sensor issue or an alignment issue (likely since somebody just adjusted it). The diagnostic for this type of fault tells the mechanic the first thing to check is the alignment.
Here is the diagnostic for one of the codes that could give you the failure you are seeing:
DTC C0253 00: Centering Error
Circuit/System Description
Steering angle centering is the process which calibrates the steer sensor output so that it reads 0 when the steering wheel is centered, using data from the yaw rate sensor, lateral accelerometer and wheel speeds. Under normal circumstances steer angle centering occurs after approximately 10 seconds of driving in a straight line on a fairly level surface (i.e. a typical road) at greater than 10 km/h.
The usable output voltage range for the yaw rate sensor signal and lateral accelerometer sensor signal is 0.25-4.75 volts. The scan tool will report zero lateral acceleration or yaw rate as 2.5 volts with no sensor bias present. The sensor bias compensates for sensor mounting alignment errors, electronic signal errors, temperature changes, and manufacturing differences.
Conditions for Running the DTC
The vehicle speed is greater than 40 km/h (25 mph).
Conditions for Setting the DTC
The vehicle has been driven for 10 minutes without completing steer angle centering.
Action Taken When the DTC Sets
• The EBCM disables the VSES for the duration of the ignition cycle.
• The driver information center (DIC) displays the SERVICE ACTIVE HANDLING message.
• The antilock brake system (ABS) and traction control system (TCS) remain functional.
Conditions for Clearing the DTC
• The condition for the DTC is no longer present.
• The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
The following conditions can cause this concern:
• Improper steering alignment.
• Internal yaw and lateral acceleration sensor failure.
• EBCM internal failure.
Circuit/System Verification
Observe the SWPS Signal A and SWPS Signal B parameters with a scan tool while turning the steering wheel left and right. Verify that the SWPS Signal A and SWPS Signal B parameters increase and decrease smoothly when the steering wheel is turned.
⇒ If the SWPS Signal A and SWPS Signal B parameters do not change smoothly, replace the steering wheel position sensor.
Operate the vehicle within the conditions for setting the DTC. Verify DTC C0186, C0196, C0253, or C0710 are not set.
⇒ If DTC C0186, C0196, or C0710 are set, refer to Diagnostic Trouble Code (DTC) List - Vehicle.
⇒ If only DTC C0253 set, replace the yaw and lateral acceleration sensor. If DTC C0253 sets again, replace the EBCM.
Again, this may not be the code that you will see but the diagnostics will be similar for the other codes.
Bill
well this turned out to be a huge issue and we found out the car was unsafe to drive. After troubleshooting the Ucodes we found a issue with the steering sensor. Upon investigation turns out the steering column was coming apart and the bearings had already jumped out of place and fell withing the column. I really have to thank Huffins Chevy and GM for not only finding this but getting the parts overnight-ed so this can be fixed early next week.
St. Jude Donor '11
Horror story avoided. Wow!
wow thats crazy, my 2010 GS showed me that message all winter, now i havent seen it for two months, probably should have someone check it out ASAP. Glad it worked out for you.
what parts did they change out ? I had a similar story where someone did a cam swap and didn't disconnect the steering column so it pulled the bearing out of place right where the swps goes. the swps was just sitting on the shaft and not reading anything.
I got the bearing back in place and a new sensor on but it's throwing c0253 immediately upon startup (before the car is even rolling)
