Please help me!!! white smoke and water!!
Old 10-29-2011, 01:01 PM
SpryGeezer
SpryGeezer's Avatar
"Killer" B intake, well-named.
Old 10-29-2011, 04:35 PM
pcguy2u
Support Corvetteforum!
pcguy2u's Avatar
Old 10-30-2011, 06:47 PM
littlefranks
littlefranks's Avatar
Originally Posted by Z06SlapMopar
there is a monsoon in south florida right now and i hit an unexpected puddle ( "water" not the type of dog) and my car bogged and then shut off. i came too a complete stop then tryed too start the car and it did not work. i sat there for one min and then tryed again and it started but the idle felt a little rough. the whole way home i did no more the 15 miles/hour. at a couple red lights i saw white smoke and the same when i pulled in my driveway. i think water got sucked im my intake i have the killer bee 2 on an 08 LS3 car.
AM I TOTALY FU*KED???
u didnt mension if the check enginge light was on or flashing ,and what codes.1 thing i know, is that if the car started and you drove home few things to think about .1 airfilter is saturated and the airflow coming across the mass airflow will be low .causes car to run rough.try drying air filter and mass airflow sensor.car could have a poss bent rod causeing lack of compression in that cylinder which could believe it or not cause white smoke dew to unburnt fuel burning in exhaust.i would check out air filter first if you still have problems call hps like mike said .
Old 10-30-2011, 06:53 PM
littlefranks
Ps ,sorry about the grammer .Inside joke. Sorry had to do it.Hope it turns out well for you.
Old 10-30-2011, 07:43 PM
lastcowboy
lastcowboy's Avatar
well....sounds like a blown head gasket ,bummer. good luck
Old 10-30-2011, 08:51 PM
need-for-speed
need-for-speed's Avatar
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
heythere littlefrank.no worries.we like how u talk.
Old 10-30-2011, 08:52 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
p.s. as mentioned above OEM air intakes can injest water too. I did it to a Lumina and it bent a rod. It was my company car so fortunately it did not cost me.
Old 10-30-2011, 09:21 PM
laconiajack
laconiajack's Avatar
Adding an aftermarket air intake is definately asking for trouble, and adds little if anything significant to performance. Of course, if you drive through standing water at excessive speed you can also damage your car, even if stock. Driving head-long into a large tree at speed will also yield similiar results.
Old 10-30-2011, 10:06 PM
06 C6 vert
06 C6 vert's Avatar
The water got all the way into the cylinders, end of story
Old 11-01-2011, 08:44 PM
Z06SlapMopar
Z06SlapMopar's Avatar
Thankyou everyone for the input and comedic relief.
There's allot of good people here on the Vette Fourm
Btw I got it towed too the best shop I know
Old 11-01-2011, 08:50 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
Best of luck.
Let us know how it turned out ...... or, if you need more advice
Old 11-02-2011, 12:43 AM
Like dem Vettes
Like dem Vettes's Avatar
Originally Posted by JScottH3
I had that problem with my old Tahoe. Turned out to be a blown head gasket. The white smoke was coolant. I would suggest you check your compression, and make sure no water got in your oil.
Compression may not be the best indicator. A shop can place an emissions probe over the neck of the radiator with the cap off and engine running at normal operating temperature.. If hydrocarbons are present, the head gasket is bad.
Old 11-02-2011, 02:46 AM
  #33
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
If your car is still on the power train warranty take it to a dealer to have it checked. If the problem is due to water ingestion the comprehensive insurance will pay for the repair if it is due to a mechanical defect the warranty will pay for the repair. If the insurance pays for the repair and the dealership does the work you still have warranty coverage on the engine until the power train warranty runs out or the 1 year/12K warranty on the repair runs out.
Bill
Old 11-02-2011, 02:52 AM
  #34
speedlink
speedlink's Avatar
You're right. Grammar and punctuation are horrible.
Old 11-02-2011, 09:40 AM
  #35
Landru
Landru's Avatar
Received 1,045 Likes on 819 Posts
Originally Posted by ospreycorvette
Aftermarket intake does it again, you gain 4 hp but put the car at risk.
To each his own; but, I'd have to agree.
OP's car started & driven so he may be lucky, time'll tell.
Used to hear horror stories of HL occurring in downpours/standing water with certain aftermarket intakes on the bottom breathing C5s from time to time. Devastating. Was the #1 reason I never got one on my '03 AE, '06 or Z06.
Quick Reply: Please help me!!! white smoke and water!!
