C6 Starting problem - please help!
Old 07-26-2015, 08:44 AM
  #81
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by scullman37
A code reader cannot communicate with vehicle if it cannot be set to run.
Read the codes. With the symptoms you describe you will have many. Yes, the car needs to be in run mode for the code reader to communicate and you do that by holding the bottom of the start button for 5 seconds until everything lights up as if the engine were running. It's described in the owner's manual.
Quick Reply: C6 Starting problem - please help!
