C6 CAGS 1-4 Skip Shift Bypass Fuse
I saw the recent thread reference the need for CAGS, but did not want to hijack the thread; Hence, my question.
Has anyone installed the fuse in their C6? A vendor has them on sale for $14.99. If the fuse is installed, will it cause a disruption/fault to the computer system and/or cause a Check Engine light Code? Will installing the fuse cause warranty issues/concerns?
I'd obviously prefer the fuse over the cable that requires one to lift the car and install the wire under the car...
Any feedback would be greatly appreciated.
Tks in advance,
B
Tks in advance,
B
Grandsport12 (04-09-2016)
you can get the fuse in a box of 2 for about 1.35 at your local parts store...any vendor asking 14.99 is riping you and me off.
I've had mine for a year now, I keep the spare in my glove box. No lights, and the darn thing never forced me to go into 4th again! great 75 cent mod!
St. Jude Donor '12
http://xse.com/leres/z06/cags.html
Check this thread. I just read that some have had the LED in the fuse go out, which cause the CEL. Blow two of them and keep one in the console...I haven't installed mine yet, but I did buy the smart fuses and plan on trying it in the next couple of weeks. I have 1500 miles on my GS and have really only been forced into 4th a couple of times, so it hasn't been at the front of my mind.
Cheers, B
Didn't work on my car; 2012 Centennial 4LT.
Plugged it into the #10 slot as the directions indicated and it turned off all my tail lights plus didn't deactivate the CAGS. The light works on the fuse but that's about all. Could be the wiring is a little different on my car.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
http://xse.com/leres/z06/images/cags-smartfuse3-sm.html
And yes on the #10, if you read what each fuse does in the manual, the #10 is the only one that is tied to the trans. Like I said, the wiring must be different on the 2012/4LT.....
I know for a fact that the wiring harness is different between the NPP option and Non NPP.....could have something to do with the 4LT.
NCM Lifetime Member
Yup, no and difference.
The best solution IMO is a fuse with an SMD internal resistor soldered, like somebody did. I'd definitely pay $15 for that, but not for a normal LED fuse. If the $15 fuse is indeed one with an internal SMD resistor, please post details. Couldn't find any. Thx.
Houston Events Coordinator
One Question: What does using either of the two methods (fuse or wiring to transmission) do to my warranty? Do I have to undo when I take into the dealer and re-do after I leave the dealer??
Moderator
Received 3,570 Likes
Seven month old thread.
