jack by frame or cross member
My understanding is frame is for 4 point lifting only, to avoid twisting done with single floor jack. Manual does show center of cross member the place to lift whole front or rear end. I can do this with ramps and long low profile jack and block of wood to protect aluminium cross member. Does anyone no if it matters either way?
Twisting is not an issue with the C6 as the frame is extremely stiff. When you are lifting from the aluminum pieces, you want to use something that will not mar the surface as that can be a starting place for a crack...a piece of wood or hard rubber is fine for that.
For additional information on this, you might want to try searching "Jacking Locations" on here. There have been numerous posts on this subject and some with pictures and detailed discussions on the pros and cons of jacking in different locations.
Received 8,928 Likes
You can lift at the cross member or the frame. The frame spots are made for a lift but there is no harm using a jack there. All you need to for jacking under the crossmember is a jack that spreads the load across both sides of the cross member rail from front to rear. If you look at the cross member rails you can see they are shaped like inverted Us. All you have to do is bridge across the U not across the car. Just think of the jack as a jackstand and place the jack pad in the same place you would place a jack stand. No need for fancy rubber pads or boards.
Most people use lift pucks and jack from the frame since it is hard to get a jack far enough under the car to use the cross member. I jack from the side and then use jack stands under the cross members.
In the rear you can jack in the center of the cross member and put jack stands at the ends. My jack has a 6 inch wide head so it easily bridges across the cross member.
Bill
Bill
I have been lifting all of the C6s in my care from the front and rear crossmembers using a pressure-treated pine lifting beam I made to spread the load. With the 01Z, I just did a single point lift in the front and rear using a 10lb plate on the jack cradle.
CF Senior Member
Either way is fine. At home I most often drive onto wooden board ramps and use a floor jack with a crossbeam adaptor attached to lift the front (or rear) of the car from the preferred lift points. I've got 2 adaptor beams...on the one I use for the front of the car I removed the extension arms and affixed the rubber pads to the ends of the adaptor beam frame. With 2 jacks and 2 adaptor beams it's easy to lift the entire car and then place jack stands under jacking pucks.
For a quick wheel change at the track I have a small Craftsman floor jack that slides under the side rails and I lift from the point where jacking pucks would go. Always follow safety procedures but when lifting a corner/side of the car it's especially important to be on level ground, use chock blocks and most importantly make sure the jack is secure so it can't slip-out from underneath the car.
