Corvette Specific Curb Alert Install Video
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
any other fuse you want to choose....I just used the seat heaters because they were easily accessible.
Any other one under 20amps is fine.
Are you sure you do not have the seat heater slot in the fuse pane anyway?
Thanks.
Jim
Thanks.
Jim
Supporting Vendor
It will not interfere at all........It is not putting out enough power to come close the setting off the V1. A friend of mine has one on his C5 with a V1 and no issues at all...
I do not know the wavelength.....
Sorry
Jim
Sorry
Jim
Jim,
I watched your video on the installation. I noticed that you placed the sensor in the middle of bumper. Where do you install it if you have a front license plate bracket?
J.R.
J.R.
Supporting Vendor
One of the biggest fears with purchasing the Curb Alert is the installation, folks are unsure how "difficult" the installation is.
To make it easy for Corvette drivers, we just created a Corvette specific Curb Alert install package for the C6 that allows you to do the whole installation within 1 hour. Checkout the video on the page below and you can see the entire installation on a 2009 C6.
Corvette Curb Alert
This is a Southern Car Parts exclusive Corvette Curb Alert package for that has everything crimped and ready to go. Run the wires and plug it in to the fuse box under the passenger floor board and you are off and running.
Just select the Corvette Specific Package when checking out and we will "pre-stage" everything for you prior to shipping so you can install it exactly like in the video.
Video is down towards the bottom of the page....
Corvette Curb Alert Install Video
Thanks,
Jim
Corvette Curb Alert
Thanks,
Jim
#33
Supporting Vendor
Actually, You can use any other fuse slot you want...Just make sure and plug the fuse you remove into the extra slot on the adapter for the curb alert....
As far as install with a bra, you would have to find an open spot in the bra where you could attach the Curb Alert to the car. That might be a little tricky since the Bra probably covers everything on the front of the car.
Jim
#34
Jim
Jim
#35
