Best ceramic brake pad?
#61
Ceramic pads
I have Carbotech one piece pads on my 2012 GS. Minimal dust, no squealing and braking is excellent. Benefit of one piece pads instead of 3 padlets is more braking surface. A little more expensive, but I am very pleased with the performance.
#62
Supporting Vendor
St. Jude Donor '11,'13
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#63
My 2011 coupe has 40K and needs front pads. Will replace front and back with low dust ceramic pads. Car is only used on street and in dry SoCal climate. Still considering age of car, should I have system flushed and fresh brake fluid installed? Also, can I expect need for having rotors turned or replaced? Current brake performance is excellent with no issues other than too much dust from stock pads. Car is never raced or tracked, just an ocassional romp through canyons.
#64
St. Jude Donor '15
If you have the cash, i would just do it. Brake system and tires are very highly important things to stay on top of. They may save you and your car when you need them most.
#65
If you really don't romp around with hard stops a lot, probably can go a bit more..but mileage really isn't a good indicator. Fluid color and rotor measurement are only real ways to tell. A $20 micrometer will help.
#66
I have Akibono's on Zimmerman rotors on my Audi A4 to test the tech before acquiring same for my 08 C6, they are great exactly as you say, so they'll be on my Vette for the track next summer, I gotta figure out some ducting as well to cool things off, what I've found so far looks klugey
