100% Plug N Play LED Interior Upgrade @ JWM- Ships for free!
#41
A lot of Vette owners have complained that if you change the rear compartment bulbs to LEDs you will notice that when you close the hatch and the lights dim, they won't go all the way out. Even though the current is very small, leaving the LEDs on for a long time will run down the battery. All that is necessary to fix the problem is to connect a resistor in parallel with the rear compartment LEDs. Some of the LED suppliers sell these resistors.
#47
Wanted to thank Jhonothan for the interior light kit. Just got them installed and the difference is impressive to say the least! The bright white really compliments the Arctic White exterior.
Install was a bit challenging...not hard but some awkward angles to work with and the map lights are frustrating. Trying to get that damn kite string slipnot around that bulb and then tighten it...arrrgggghhh!
Anyway, thanx. I love 'em
#51
Just installed mine. They are fantastic... Do you guys make or sell any for the vanity mirrors? They are extremely yellow now in appearance too... Just wondering and if so, what size bulb would they require?
On another note, any suggestions about removing the glove box bulb? That one is giving me a hard time...
#54
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
LED magic
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768.This image has been resized. Click this bar to view the full image. The original image is sized 1024x768.
#56
JW,
The trunk lights that I installed worked fine at first, then half the time i open the trunk, the lights were very dim and would not light up, other times they would light up fine....any solutions? or are they defective bulbs?
#57
Cruising
I just finished installing the interior and exterior LED lights including the new high power LED back-up lights. Absolutely fantastic difference! I wish I had done this earlier. Time to do the rest of the lights. No more "Yellow" for me!
