C6 Seat Rebuild Kits @ JWM
Old 02-25-2014, 12:50 PM
  #121
kerflumper
kerflumper's Avatar
Originally Posted by RussM05
However, the blocks of high density foam keeps the OEM bolsters high so even if the frame cuts the OEM foam, the frame is not the primary support anymore.
There is no high density foam in the kit for the seat backs. Are you referring to the seat bottom or the back?
Do you think door edge plastic will be strong enough?
Old 02-25-2014, 09:30 PM
  #122
CO Lightfoot
CO Lightfoot's Avatar
Originally Posted by kerflumper
...I saw one mention here about putting tape over the frame edge to prevent it in the future. Anyone have any other ideas for tackling that?...
I don't recall if the edge is sharp or jagged.
Anyway, you can smooth it with a file or dremel.
Then cover the edge with whatever rugged material you want. No one will see it, so use whatever works... cut some strips from an old backpack, fabric luggage, etc. Then secure with glue or duct tape (or both).
Maybe even something like
camper mounting tape camper mounting tape
Old 03-03-2014, 05:14 PM
  #123
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
He is referring to the bottom. For the sides new oem foam works. I have used the tape method mentioned myself. It worked well for the year or so that I ran with it.
That one will require some creativity. I don't have a solution for sale I'm afraid.
Old 05-03-2014, 08:57 AM
  #124
JW Motorsports
Banned Scam/Spammer
In stock
Old 12-17-2015, 07:45 PM
  #125
dbletap_ed
dbletap_ed's Avatar
Two questions:
Is the kit still available?
Most important question, does the kit cost any head room?
Old 12-17-2015, 08:27 PM
  #126
ncvette_1FUNRIDE
Support Corvetteforum!
ncvette_1FUNRIDE's Avatar
2015 C6 of the Year Finalist
Originally Posted by dbletap_ed
Two questions:
No longer a forum vendor and hasn't been on the forum for 6 months.
Old 12-17-2015, 10:12 PM
  #127
RussM05
RussM05's Avatar
Received 1,013 Likes on 365 Posts
Two questions:
The kits are available from eBay, West Coast Corvette, Southern Car Parts, and Caorvette Central.
Old 03-12-2016, 05:43 PM
  #128
Lukes07Vette
Lukes07Vette's Avatar
don't know if this thread is still active but i could use some advise. I'm curtly in the middle of putting my seat back together and the reclining lever no longer fits, there isn't enough room to side it back on.
Has anyone come across this problem?
Old 03-12-2016, 06:33 PM
  #129
ncvette_1FUNRIDE
You have to be able to slide the reclining lever back onto the shaft enough so that the retaining clip gets back to the slit in the shaft.
If it won't slide on that far, you either have some padding in the way or the shaft has moved slightly back into the seat frame.
I actually used a Dremel to take off a little off of the back edges of the handle (not the shaft hole part) so I could get it to slide onto the shaft far enough to catch the slit.
Also, If you don't get the plastic cover back on correctly then you won't be able to get the recliner handle into the shaft hole far enough to catch on the slits in the shaft.
Old 03-13-2016, 12:20 AM
  #130
CHEV AGAIN
CHEV AGAIN's Avatar
Did you cut the foam where the metal frame comes up the sides? If not nothing fits right.
Mark
Old 03-13-2016, 12:26 AM
  #131
ncvette_1FUNRIDE
Mark
Must cut foam for metal bracket to fit right.
Old 04-21-2016, 08:19 AM
  #132
Enterprisehunter
Enterprisehunter's Avatar
Bought this a little over a year ago and already need to get another one. The foam used to cover the side bottom bolster is WEAK! It squishes within a year. Be forewarned.
I just bought another kit for the same seat I repaired a year ago.
Old 05-03-2016, 05:33 PM
  #133
Scott S
Scott S's Avatar
Originally Posted by Never-Enough
Has anyone thought of putting memory foam in their seats? I'd love to do that to all my cars.
The problem with memory foam is that it is rock hard when cold. Put a piece in your freezer.
Scott
Old 08-09-2016, 03:39 PM
  #134
Tom Gilfoy
Tom Gilfoy's Avatar
Does the fact that some seats are heated come into play.I don't see any mention of the heating element (pad) and where it goes in relation to the foam.
Old 08-09-2016, 04:01 PM
  #135
ncvette_1FUNRIDE
Heating elements have a different seat pattern in 2012 and 2013 compared to 2011 and earlier.
You can reuse your heating element. I don't have heated seats but I have seen others that did and upgraded their foam.
Old 08-09-2016, 04:36 PM
  #136
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
The heating element goes in the same place; on top of the foam. The seat rebuild kit goes on the bottom of the foam. I just did a foam replacement and used the rebuild kit to protect the new foam. R&R of the heating element was part of this job. Just needed to use a little 3M glue to keep it in place.
Quick Reply: C6 Seat Rebuild Kits @ JWM
