Custom Logo Airbags and 2012 steering wheels for all C6's available at GMPARTSHOUSE
What is involved in removing the 2011 airbag and replacing it with the 2012 airbag? Can I do it or does it require a GM technician? Are warranties affected?
The only tool you need is an allen key or other skinny object to poke through the holes behind the wheel to release the latches.
It's far simpler than the phrase "air bag replacement" would imply.
So your saying that this is pretty easy to install. What about the steering wheel if I replaced it? What's that entail?
It takes about 10 minutes. All you have to do is pop the two latches inside the wheel, carefully lift the bag off, disconnect the two electrical connectors (which have safety clips) and then connect the same two connectors to the new bag assembly and simply press the bag back into the wheel (it will lock in place automatically).
1) (recommended) disconnect the battery OR pull the SRS/Airbag fuse for safety.
2) use an allen key, small flat screwdriver or other long thin device to remove the airbag assembly. There are small holes on the back of the steering wheel behind the airbag (oriented at about 4 and 8 o'clock).
3) feel around with your tool of choice until you feel something springy...push inward to release that side of the bag. repeat on the other side and the airbag will be free of the wheel. This is probably the most difficult part of the whole deal as the thing your aiming for is nothing but a thin metal bar like a piece of wire. It may take a minute to find and catch it.
4) carefully remove the yellow safety clips and disconnect the two plugs from the back of the bag (color coded, you can't mess it up). Set the bag assembly aside (don't lose those little clips!)
5) you might want to snap a quick photo of the inside of the wheel to keep track of where/how the wires behind the bag tuck in.
6) disconnect all applicable electrical connectors (horn and audio/bluetooth if equipped).
7) Remove the large center nut that holds the steering wheel on the shaft. I believe it's about 21mm or so.
8) The wheel and the shaft have alignment marks. Take note of these for re-installation. For what it's worth, my wheel felt like it wouldn't really go back on unless it was oriented correctly but I suppose your results may vary. In any case, it's no big deal if you just pay attention.
9) grab the wheel at 3 or 9 o'clock and pull gently while simultaneously giving the opposite side a little whack with the heel of your hand. reverse and repeat. The wheel will work itself loose within two or three hits. No special puller needed.
10) be careful not to get any of the wires caught as you remove the wheel from the steering column.
11) Reverse the process with your new stuff taking note of the wheel alignment and making sure the wiring behind the bag is tucked in where it belongs so the bag simply snaps back into position.
Nothing to it.
The wheel will work fine even with the buttons. If you want to make them functional, I believe it can be done by sourcing the 3LT-specific clock spring and column wiring harness from a newer car.
Premium Supporting Vendor
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Yes, is pretty easy. I'd say a 2 out of 5 on the difficulty scale only because you have be careful with those plastic yellow clips and not break them or your airbag light will stay on.
**DIY Steering Wheel Removal and clock spring**
Here is what I read before removing the steering wheel and air bag.
http://forums.corvetteforum.com/c6-c...ck-spring.html
very useful info thanks for posting
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
#35
St. Jude Donor '08
I've asked this question in a related thread but I'll ask it again, maybe someone in this thread will have an answer. Will the C6 steering wheel work on the C5? I'd like to put one of these on my 2000 FRC.
#36
My 06 3LT manual has no steering wheel radio controls. Is it available like that? If not and I purchase the 2012 wheel can these controls be made to work with the nav? If so what else is needed? If I read it correctly my original air bag can be reused in the new wheel.
#37
Just ordered Suede wheel with red stitch, GS Airbag, Suede shift ****, and shift boot all with red stitching. Can't wait to get these on the car. Still debating on e-brake...
#39
I received and installed my 2011 Suede steering wheel a few weeks back. What a difference it makes. So much more grip. They should be all made this way. 100% improvement. Some don't like suede as they say it's hard to clean. To each their own. I have driven and raced 100's of different types of cars and this is one of the best feeling wheels I have had my hands on. Great price! Very easy to install. Highly recommend. Thanks GMPartshouse!
#40
