ZR1 v. Z06
ZR1 v. Z06
What's the difference between a fully loaded ZR1 and a Z06 (same year, also fully loaded), beside the engine and price?
If the cars were identical except for the engines, one might be better off starting with the Z06 and building up a great engine, from the bottom up, with FI of some kind.
But if the ZR1 has features not available on the Z06, maybe not.
The Consigliere
Received 5,444 Likes
You can get a Z with the same suspension and brakes as the ZR.
You just can't get the glorious LS9 in the Z. So diff comes down the engine (if comparing Z07 to ZR).
No need to mod the ZR; but if you're the modding type, you can get more reliable power out of the ZR for small $ relative to the LS7.
Resale value.
You'll get your money back on the ZR1 (proportionally), and lose your a$$ on a modded Z06.
Plus, at car shows, both are in the same category (wide body C6's), and the ZR1's take home the hardware
OnPoint, you wrote: " you can get more reliable power out of the ZR for small $ relative to the LS7."
Is your point that you pay less for extra ponies in the ZR? I sorta doubt this'd be true if you took original cost into account.
Good points, though, about retained value. It might be that one could make a few reversible changes to the ZR and get maybe comparable power to the Z0. If so, one could restore the ZR to "stock" condition when it came time to sell.
Of course, the chrome plated body panels might be a tipoff...
And Racer wrote, "KABOOM!!! " That's about what happened to me when I took in his avatar!
I appreciate the input.
The Consigliere
I wasn't using acquisition costs. Just costs of mods. One can get a ZR to low/mid 700hp for just a few thousand with excellent durability/reliability. Tougher (more expensive) to do that with the LS7.
I mentioned that in case OP is into modding, as some folks are (I myself had a modded Z).
Obviously modding either one tosses the bulk of the drivetrain warranty. So stock to stock, you get more car with the ZR. And if you mod, you still get more car for a comparatively smaller mod investment, and with a more robust engine.
All that said, we're talking about the two best vettes ever made. Pretty tough to go wrong either way.
If you want faster you have to modify either one.
Who mentioned modded? You lose your *** on a Zr1 just as bad as
A Z-06. Depends on how much you paid!
ALL cars lose value and fast,........from Lambo's to Kia's, prove I'm wrong and I'll send a prize. Z06 can be made fast.....real fast but do you sacrifice driveability?? Probably. ZR1 starts with better platform and has more potential for sure. Holds value better ?.....hell no! Both are lousy as investments so just enjoy them and with whatever route you go with on the mods.
