Mild to Wild
Mild to Wild
Is everyone doing the standard install or the battery saving one. Also what causes it to drain the battery? Has anyone had any issues with a dead battery?
Cruise-In VI Veteran
Cruise-In VII Veteran
I did the standard install on my last 6 C6's. I try to remember to turn the switch off (open the flaps) when I stop, before I turn the car off. It's pretty easy to remember, because I like to hear the pipes before I turn the car off. This makes sure there is no drain on the battery.
I've only had one dead battery, and that was on an 08 coupe when it was almost 2 years old......usually close to battery life on these cars. This is when I started to open the flaps before turning the car off.
Standard install 3+ years ago, no problems with battery drain. Always in the W position. (open).
Thanks all, that's what I was lookin 4. Thanks again to hungryhipo for the mild to wild set up, great member to deal with and no hassel transaction.
Thanks all, that's what I was lookin 4. Thanks again to hungryhippo for the mild to wild set up, great member to deal with and no hassel transaction.
Instructions/pictures for the 2 ways to install/setup the M2W.
http://eliteengineeringusa.com/Insta..._Mild2Wild.pdf
Scroll down for the zero drain install
Standard install. Had it for about 4 years now. Since it's a daily driver, there hasn't been much time for it to drain the battery. The pipes are usually closed when I drive through my quiet neighborhood and when I park. Haven't had any issues. Still running the original battery.
installed mine in the standard way, always have mine in the roaring position when I shut it down. Had it for 6 months and no battery issues yet. eddie
Standard position. I always have the flaps open, except when on a longer drive on the Freeway, so no problems. But, I also put the float charger on the car, as I drive the car infrequently.
