Results of upgrades to my base C6 suspension
#61
Your changes have made for more oversteer (loose).
Here is some good suspension information regarding swaybars.
http://www.houseofthud.com/cartech/swaybars.htm
What great article,thanks for posting it!
(This is a great forum)
JR
#62
Decision
All Concerned,
The front spring rate for a C6 with the Z51 option or the GS model is 526 lbs.
The front spring rate for the C6 Z06 is 531 lbs.
Does the extra 5 lbs. of spring rate really make that much difference in front end stiffness/handling?
The reason I ask is...I was thinking of changing out the front spring on my 2010 GS (currently the car suspension is stock except for Koni FSD shocks) with the Z06 front spring and installing a ZR1 front sway bar. Or just keep the GS stock front spring and installing the ZR1 front sway bar. The rear of the car would remain unchanged, These applications would be for street use.
Anyone have any input on those set-ups???
Please advise.
Respectfully,
David
Please advise.
Respectfully,
David
Respectfully,
David
#65
Suspension question
I am running Z06 size wheels, tires and brakes with a widebody complete on z51 springs with F55 shocks. Would going with Z sways and springs actually do anything on the handleing for me? Flatter corners etc or just cause the need for coilovers and F55 delete. Can the z set up run well with the current shock set up? I like being able to adjust the ride at the switch so I would like to keep that option.
#66
zr1 front and either z06 or z51 rear
base, brake, c6, corvette, design, improvements, performance, rear, sale, shocks, stiff, suspension, suspention, upgrades, z06
