Sullivan Racing Pedals
NCM Lifetime Member
I have the exact same ones from them, absolutely love the look and feel on the pedals
I was looking at these sullivan pedals for my 07 M6 coupe... what's the installation involve?? Do they just screw on?? How about the gas pedal?? Do you have to take it apart?? Thanks!
They look identical to Performance Pedals, and same pictures; probably same vendor. They're a bit cheaper in grid or block, but significantly cheaper on satin. I'll order exactly those (grid), but in aluminum color, so the brake and clutch stems don't clash. But it was a close decision; they look great in black. Thanks for the link .
The gas and footrest attach with machine screws. You have to drill pilot holes first, then just screw into the plastic.
SRP Pedal
They make a great product. I needed a wider clutch pedal so my size 13 shoe wasn't also pressing the brake. Brian gladly made a set with a 1" wider clutch pedal and solved my problem (at no extra charge). The fit and finish is excellent and they're easy to install. I highly recommend SRP.
