Any Way To Get Scratches Off 3M Film Protector
I have the nose of my 2007 protected by the 3M film protector. I just noticed some scratches in the film and short of replacing it I thought I would ask if anyone has a remedy to remove the scratches.
Unfortunately that is one of the disadvantages of a clear bra. I had it on my 08. The only thing I hated worst about the scratches is that it didn't do anything to protect the radiator area from debris damage.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
If it's genuine 3M and not Ventureshield, you're supposed to be able to hit with lacquer thinner and take out the scratches.
At least that's what our local 3M shop says
Does it have to be done by a professional?
If it is 3M (the best as far as I’m concerned!) then use rubbing alcohol.. I've got a complete wrap and use the rubbing alcohol all the time.. will remove surface scratches every time..
That is the reason I don't use 3M anymore is because it scratches easily. I now use Cleartastic which holds up much better. Either way I discovered a product from Adam's specifically made for the clear bras. It is called clear polish and clear spray used after polish as a protectant and conditioner. I use it w/ a orange pad and an orbital polisher. It works pretty well and takes out most scratches. You have to be careful w/ 3M when it's warm and what towels you use on it because I found it to scratch very easily compared to some of the competition out there now. Check Adam's my stuff has lasted so long now that I haven't bought any in a couple of years now!! Good luck
I own a detail shop and while alcohol does work you have to be incredibly careful with it as it can go very deep, very quick and ruin the bra We use a very mild abrasive. the best we have found is Zaino ZPC or Zaino All-In-One, or Meguiars Scratch Remover by hand.
It used to be the standard cleaning agent for PPF. It's not now. Take the white cap off your can of Plexus and spray some into it. Let it sit and dry and have a look for yourself. Any "Professional" installer of PPF should know this, if they don't I advise avoiding them because they haven't kept up with their certs and spoken to a industry rep for awhile. Bottom line it's your car and you probably spent a decent sum of change to protect it with quality PPF. If you want to shorten the life of the PPF with a $5 dollar can of Plexus that's your business. I look forward to having you come to me so I can replace it for you and bill you again.
Mine is starting to dull around the mirrors and a couple places on the front. Any suggestions?
St. Jude Donor '12
Questions: Proper Paint Protection for New Corvettes"
I had some questions about what was the best paint protector for my car. Speed Specialists out of TX recommends "Venture Shield". Check out his posting on my question. Hopes this helps.:woohoo :
