White DRL's which are NOT led's
http://www.ebay.com/itm/330584784359...84.m1423.l2649
$17 shipped
they don't blink, they are back up lights, The original backup bulbs in the DRL'S blink fine
$17 shipped
So, the apparent key (in my case) is to find bulbs which are NOT led but ARE 6k in color... I see the return to stock in my future...
If you're considering swapping your back-up lights for your DRL's, then try these replacement 6000K HID back-up lights from corvette-mods.
http://forums.corvetteforum.com/c6-c...e-84-99-a.html
No resistors need for these bad boys, but using an HID for a turn signal may be iffy.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
3157 dual filiment bulb specs and picture
tem Number: 3157 Lamp Type: Miniature Filament: C-6 / C-6 Voltage: 12.8 / 14 Design Amps: 2.10 / 0.59 Watts: 26.88 / 8.26 Average Life Hours: 2,000 / 10,000 Bulb Shape: S-8 Max Diameter: 25.00mm Max Length: 53.00mm Base Type: D.F. Osram Sylvania is a global leader in the Automotive Lighting as well as the leader in supplying quality products to all major automotive manufacturers.
Hey Guy's check these out.....
There are being sold at http://www.ecklerscorvette.com
Description
Electrical Components such as wire harness, bulbs and fuses are (Non-Returnable Parts) Always refer to a factory service manual when diagnosing engine service problems. You can damage electrical components if the proper procedures are not followed. Be sure you are replacing the correct part. Essential to run LED indicator bulbs, LED bulbs draw only 80mA and there fore your indicator will flash faster due to a blown bulb warning. There isnt enough start-up current made the mechanical relay click in a normal flasher. This fully electronic no load flasher unit is made for LED technology and will drive a limitless amount of LED indicator bulbs safely. Ground Black wire to a body or dash ground.
Description
NCM Lifetime Member
Link ?
Got a link to the actual page on their web site ?
NCM Lifetime Member
Thanks. In the mean time, I found them on the bay for less.
#34
Please post up with pics when you determine where/how to connect this to the C6's computer controlled flasher circuit.
If only it was this easy/old days.
#35
NCM Lifetime Member
#36
#37
Description
Description
#39
NCM Lifetime Member
#40
