What air pressure is correct Z51 2008 C6
Old 02-25-2012, 05:38 PM
Pitbull11
Pitbull11's Avatar
Default What air pressure is correct Z51 2008 C6
Is the recommended 30psi frt and 30psi rear what you guys run? Did a search and did not see anything on tire air pressure. Dealer put 35psi in the fronts and 33psi in the rears. What do you guys recommend for good tire mileage and everyday driving?
Old 02-25-2012, 05:52 PM
TJay74
TJay74's Avatar
Your drivers side door jamb should have the specs, I run mine at 31f/31r, anymore than that and it rides like a tank.
Old 02-25-2012, 05:54 PM
AC04
AC04's Avatar
I keep mine @ 30 psi like the manual reccomends
Old 02-25-2012, 05:58 PM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
With OEM wheels and tires, 30 psi cold pressure. Cold meaning you haven't driven on the tires.
Remeber also, tire pressure is not a set it and forget it item. Tire pressure will vary based on air temperature. Tire pressure will change approximately 1 psi for every 10 degree change in temperature. If the temp goes down, pressure goes down. If the temp goes up, the pressure goes up accordingly. Tire pressure will also increase as the tires heat up while driving.
You should check and maintain your tire pressure to 30 psi cold as the outside air temperatures change.
Old 02-25-2012, 07:39 PM
budgreen3564
budgreen3564's Avatar
tire jockeys never inflate properly
Old 02-25-2012, 08:07 PM
VET4LES
VET4LES's Avatar
Old 02-25-2012, 08:13 PM
Marc V.
Marc V.'s Avatar
Old 02-25-2012, 08:14 PM
blkvet6
blkvet6's Avatar
OMG, look at the driver's door jamb.
Old 02-26-2012, 12:53 AM
Pitbull11
Pitbull11's Avatar
I know what the door jam states. Just wanted to know if owners have had better results with other Psi? Thanks to everyone for the info. Since the temp varys only 6 degrees from summer to winter here on Maui I will move them all to 30 Psi. I did do a search before I asked this question and could not find any other info. New to the Vette so have patience with me.
Old 02-26-2012, 01:02 AM
Houston Z51
Houston Z51's Avatar
I keep 30 all four.
crusher1
crusher1's Avatar
Just as it says......I keep mine 30psi all the way around
Old 02-26-2012, 01:05 AM
cclive
cclive's Avatar
Too much air will wear a ring right around the center of the tires. With stock size tires and wheels, run 30...as Paul said above.
Up at the volcano, the pressure will read higher, and the air will feel like it does here!...
Old 02-26-2012, 03:28 AM
MisterMidlifeCrisis
MisterMidlifeCrisis's Avatar
I run 1 PSI higher in the fronts than the rear, and 0.5 PSI higher on the driver side than the passenger side. This creates the at-the-limit handling balance I'm most comfortable with, considering the ride height, suspension, alignment, and tires. It's also a compromise between dry and wet behavior, as my Corvette oversteers more in the wet, and presumably oversteers even more the slicker the surface. My left front tire pressure is 33.5 PSI.
Old 02-26-2012, 08:14 AM
dvilin
dvilin's Avatar
Received 7,918 Likes on 4,804 Posts
Old 02-26-2012, 08:45 AM
JKbride
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Anyone of you running Nitrogen to avoid pressure swings associated with the temperature?
Old 02-26-2012, 08:55 AM
su8pack1
su8pack1's Avatar
30 PSi of real air only works for me.
Old 02-26-2012, 09:37 AM
Bandit1
Bandit1's Avatar
30/30 psi
To What air pressure is correct Z51 2008 C6
Old 02-26-2012, 09:46 AM
Quick Silver Z
Quick Silver Z's Avatar
Received 1,491 Likes on 1,005 Posts
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I keep 30 all around and recheck monthly. I also check after any service and find the "pros" almost always over inflate considerably.
Old 02-26-2012, 09:59 AM
bearphoto
bearphoto's Avatar
SoCal Events Coordinator
St. Jude Donor '12
I had nitrogen in my 09 vert, I did not add it, it was in it when i bought the car new. It did help as I am at 7000 ft and have big temp swings but i dont think i'd go out of my way to pay or add it. (I'm sure i paid for it when i bought the car, lol)
Old 02-26-2012, 10:01 AM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
X2 just to reinforce the message....
Quick Reply: What air pressure is correct Z51 2008 C6
