Random Orbital Polishers > Really all that necessary?
Received 3,085 Likes
2021 C6 of the Year Finalist - Modified
I did a search to find info on random orbital polishers. Most threads deal with what brand of polisher members here like best, or proper ways to remove swirls, etc.
I was seriously thinking about buying one until I looked at some youtube videos on how to use them.
Seems like they are used to [apply] the wax/polish, but after the wax is applied, you need to still use the old-fashioned way to remove the wax, and that is by hand with a 100% cotton or micro-fiber towel.
For the life of me, I can't really see the need for a $130 - $180+ electric polisher just to apply wax ... That's the easy part! ... Taking the wax off and buffing to a high shine is the harder part, but again, that's all done by hand even if you own an electric random orbital polisher.
Now, I can understand that an older neglected car with lots of paint fade would benifit from using a heavy compound applied with a polisher to remove the oxidation, but most of us here don't drive Corvettes with heavily oxidized paint ... And to be honest, if I had a car with real faded and oxidized paint, I would take it to a paint refinisher and have it machined out by a pro using an industrial rotary buffer and compound.
So, other than to maybe making removal of some "swirls" in the paint a little easier, is buying a random orbital polisher really something "I just can't live without" if all I would normally use it for is to wax the car?
Thank's for any input
Ron
Ron
See, that's the reason I find it hard to justify buying a random orbital polisher.
Removing swirls in the paint is great, but how often do we really need to do that? ... enough to go out and buy an electric polisher?
I was also looking at a Porter-Cable and a Meguire's model polisher, but they are somewhere around 4.5 amps, whereass the Griot's Garage polisher has a more powerful 7.0 amp motor.
And I guess you don't use it to remove the wax either.
What color is your car? For a dark color it removes swirl marks MUCH faster than by hand. I think it is mainly for removing swirls, not for applying wax. At least that's how I use it.
I was thinking about buying the Griot's Garage 6" random orbital polisher, but I see that microfiber pads are not even available for that model.
I still haven't bought one, but I am strongly considering one, given the time savings.
BTW - only used it to apply the polish/glaze/wax..not to remove.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I have never needed one, in 50 years, and all my cars have looked great! Including the 40 plus years of rain, snow, ice, salt water, and whatever else New England weather provided!
A while ago I made micro bonnets by cutting a 10 inch circle out of a 15" micro pad. Had my wife sew a 1/2" hem and inserts elastic band in the hem. I made it to fit over a std 6" pad. Made about 4 of them and they have lasted over 5 years and they can be washed just like any micro cloth.
until you own a porter cable you will never understand the need for a dual action polisher. it is pretty much the industry standard and most professional detail shops use them.don't let the griots 7.0 amp motor sway you. the 7424xp has more than enough power to do whatever you need. the proper pads, polishes/compounds for which type type of paint surface are the key to make these machines perform. and yes you can apply and remove all types of compounds,paint cleaners,polishes,waxes and sealants with the PC. you will learn the best way to use these machines is practice in as much as they all have little tricks and techniques that work for each individual user. BTW i have a porter cable.
"Random Orbital Polishers > Really all that necessary?"
YES - why else would every professional detailer on the planet use them? For the 'polish' stage of detailing a vehicle they are irreplaceable, IMHO.
A: Random Orbitals produce great results in the hands of the right individual. But, also, professionals have to detail a lot of cars to run a successful operation. Random Orbitals enable them to do more, good work than they could otherwise do by hand.
They make your job easier....especially when using Zaino or doing multiple coats or you had a torn rotator like me.
My wife bought me one a couple of years ago and am really glad I have a Porter Cable.
I have both a random orbital and a rotary polisher. I mainly use the rotary for paint correction (especially on finicky corvette clear coat) and the R/O for wax application and hologram removal. I can fully wax a car with a R/O in about 15 minutes. Both machines have their purpose. Just like regular slotted and philips head screwdrivers.
