2013 last year of the LS series motor
Old 03-07-2012, 02:07 PM
lebvette
lebvette's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Default 2013 last year of the LS series motor
This might be old news that I figure has been hashed over a few times, but this is what I heard. Take it for what it's worth....hearsay.
Last night at our club meeting a friend told me...he was at a seminar where a GM engineer was the guest speaker. The engineer said that 2013 would be the last year for the LS engines. No more LS3, LS7, or LS9's.
First time I've heard it. If the info is correct....probably going with something smaller and supercharged.
Old 03-07-2012, 02:18 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Does seem an odd statement. The LS series engines are designed around a 4.4" bore spacing that's been around since 1955 and it's easy to make smaller displacement engines, and superchargers are nothing new. Remember that they started out at 265 cu in.
Now if they are thinking of a smaller bore spacing, say 4.125" or 4.00" and then make the block out of high strength compacted graphite iron, then I could see that. Because of the very high strength, they can physically make the engine much smaller, saving weight, while running high boost superchargers, because of the CGI strength. CGI has been used in small diesel engines for several years.
Old 03-07-2012, 02:21 PM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
we will know more in about a year or so. maybe they'll call it, whatever "it" is, an LT engine. then, they'll have to change the package options to something like "1LS, 2LS, etc."
is that the old switcheroo of don aka maxwell smart days, or what?
Old 03-07-2012, 05:42 PM
C7 BOB
C7 BOB's Avatar
Uh ...... the C4 engines were LT1 AND LT4.
Old 03-07-2012, 05:53 PM
OnPoint
The Consigliere
Support Corvetteforum!
OnPoint's Avatar
Received 5,419 Likes on 2,266 Posts
I think the original LT-1 was in the C3.
I think I read somewhere that the new Gen V smallblock from Chevy will be designated LT(plus some suffix).
Won't be long and we'll all know what Gen V will be called.
Old 03-07-2012, 05:57 PM
R&L's C6
R&L's C6's Avatar
Received 1,235 Likes on 703 Posts
Originally Posted by C3 Vette Fan
With the guy in the White House now, I just hope the Corvette has a engine of any kind in the future. They could call it BO427 if they want. I just hope it has one, and it runs on gasoline.
I think they are working on solar panels for the C8.
Old 03-07-2012, 06:11 PM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
Originally Posted by Daekwan06
You make an anti-Obama post in literally every single thread I read from you on Corvette forum. There needs to be a rule where politically motivated posts get moved to their own thread.. as it contributes absolutely nothing to the subject & sends the subject off track.
Back on subject:
Wouldnt be surprised to see the LS moniker disappear. After all its a continuation of the LS1 and LS6 we saw in the C5. The engine in the C7 is expected to be more revolution, less evolution.. definitely next generation. Its expected to be smaller (reversing the current trend), direct fuel injection, higher compression ratio, variable valve timing, cylinder deactivation and stop/start. All of these are features that will dramatically increase power and/or gas milage.
Would be a surprise to see it get called the LZ1 or something of the sort.
Nothing on your list is revolutionary, all are current technology.
It's still a 4.4 bore spacing so the block size for a V8/6 will remain about the same. VVT is already on most of the motors from GM with DI on 4/6s. There is only so much you can do with the block design. So unless the V8 goes DOHC, which I doubt, calling VVT and DI evolutionary is a stretch.
Variable valve timing and DBW TBs have pretty much killed cylinder deactivation as a fuel saving means.
And yea, O sucks ....
Old 03-07-2012, 06:32 PM
R&L's C6
R&L's C6's Avatar
You talking about Oprah.......
Old 03-07-2012, 06:34 PM
C3 Vette Fan
C3 Vette Fan's Avatar
Old 03-07-2012, 06:38 PM
b4i4getit
b4i4getit's Avatar
Hearsay means nothing. The development cost for the LS series was paid long ago. If they can stuff it into the new car I have a feeling it will still be there.
Old 03-07-2012, 06:49 PM
AORoads
AORoads's Avatar
St. Jude Donor '15
"In honor of jpee"
I knew that, 99. esp. since I owned both.
back to the thrilling days of yesteryear! hail to the LT 6, LT 9, LT ?....
Old 03-07-2012, 06:52 PM
rcallen484
rcallen484's Avatar
Like the LS is a bad thing? I believe the LS series is exceptionally good but believe Gen V is due. Smaller displacement, more horsepower.
Old 03-07-2012, 06:58 PM
Mach2
Mach2's Avatar
the LS2, LS3, LS7 & LS9 us connected at the hip with the C6. The C7 should have it own engine moniker.
Old 03-07-2012, 07:59 PM
michaelinmech
michaelinmech's Avatar
Brand new engine technology, like anything else, can be troublesome . .
If there is a new engine series perhaps they should be PMS1, PMS2, PMS3
Old 03-07-2012, 08:32 PM
C3 Vette Fan
Old 03-07-2012, 08:43 PM
Cybernetic Medic
Cybernetic Medic's Avatar
Old 03-07-2012, 08:44 PM
Don-Vette
Don-Vette's Avatar
The General Motors Tonawanda, NY engine plant is currently undergoing an $825 million makeover in preparation for the production of The General’s two vital next-generation engine lines in the years to come. From what we gather, the next line of V8 engines will feature direct-injection (like the 2.4 liter ECOTEC motor) and an “advanced combustion system”. However, new technology for the ECOTEC four-bangers remains under wraps.
http://gmauthority.com/blog/2011/01/...12-v8-by-2013/
About 6 miles from my house.
To 2013 last year of the LS series motor
Old 03-07-2012, 08:49 PM
C3 Vette Fan
Old 03-07-2012, 08:51 PM
michaelinmech
Old 03-07-2012, 08:52 PM
johnodrake
Moderator
johnodrake's Avatar
Received 3,569 Likes on 1,614 Posts
Originally Posted by rcallen484
Agreed. The ONLY direct connections are that he did what was necessary to save GM and he was photographed sitting in a newly produced Corvette. Let's get off this political stuff. It will quickly lead to massive
Indeed!
Quick Reply: 2013 last year of the LS series motor
