torque specs important?
I just ordered some side skirts and read the rear wheels need to come off for the installation. I know it sounds crazy, but the car has only a few hundred miles on it and I feel like if I mess with the wheel specifications from the factory, I won't feel as safe to drive it...
seems like a silly question, but worth asking.
on wheels, not terribly important as long as you tighten then by hand correctly. on everything else, I'd say yes. Suspension may not be as critical as engine internals, but on loose bolt could lead to a slow incorrection in alignment, or just fall off. for driveline components, you must torque to specs!
CF Senior Member
It's hard to find fault with doing something right (following torque specs). I suggest you go by the book. That said, on a few things I don't always use a torque wrench.
Although I would not recommend it there can be exceptions to using a torque wrench and following specs. Years ago my friend and 'racing mentor' was helping me with my brakes. I went to his house to use his shop, home lift and the benefit of his experience. This man has forgotten more about cars than I'll ever know...he's a former sprint car driver and a long-time Corvette racer. He often uses his torque wrench but in this case he was tightening the caliper bracket bolts with a large wrench and a small sledgehammer. When I asked him about the torque value he turned with a sly smile and said "Don't worry...it's not going anywhere." He was right.
Received 2,061 Likes
The specs mean nothing, as long as you are comfortable with parts falling off or bolts breaking.
not only use torque specs, but you need to be advised. a lot of the fasteners on the c6 and c5's use torque-to-yield specs. check on whatever you are working on for the proper procedure. the procedures are there for a reason. whole new ballgame on these cars....................
