Will a LS7 Z06 exhaust fit a 2007 LS2 C6
I would like to swap out my stock C6 exhaust with something better but a new header/exhaust combo for well over 2k sounds like more than I want to buy right now. I see used stock Z06 manifold, pipe, cat combos going for cheap these days. since it is a 3", and the manifold must be a better design, I am thinking it will give me a decent performance bump.
My question is, will the Z06 manifold bolt up to my LS2 head, and will the piping fit my base C6. As always, thanks for your input.
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
If you have a manual transmission the Z06 exhaust manifolds, cats, mid pipe and mufflers will all fit no problem.
If you have an automatic its going to be very tight around the transmission. It can be done, but its tight.
Once you have installed it all, you will need a vacuum controller kit to control the butterflies.
Take a look at our thread for the Exhaust Commander All-in-1 NPP retrofit kit. It has a lifetime warranty and has many control options for your bi-mode exhaust.
If you have any more questions, let us know.
if you put complete LS7 exhaust on a 2005 LS2 manual trans car.....what has to be done to the oxygen sensors ........do the wires have to be lengthened? Or is it just the wiring harness routing that needs to be changed a bit? Thanks
