Force daytime running lights to stay ON?
Probably not, since the reason they turn off when the signal is on is so other drivers can see the signal better. Every car I've seen that has LED running lights similar to the C7 have them go off when the turn signal is turned on. I don't like the way it looks, but I doubt it's changeable for safety reasons.
I didn't notice the date either. That's one of the problems with using the search function (which many chastise posters into doing): they'll search and find an old thread, then post to it and others post also thinking it's a recent question.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
You've posted what appears to be a C7 question in the C6 Forum. If you have a C6 you can change the DRL's from filament bulbs to LED's. When you do that you will need load resistors. The colors are as follows depending on the LED's you get. White DRL. Directional amber followed by off followed by amber and then back to white when turn is completed or white, amber, white, amber until completed. If you have a C7 that is a whole different game.
