Mild to wild exhaust
#41
i know it's an old thread but..
To me it sounds like this M2W is just an electronic relay with an RF signal for the FOB. If pulling the fuse makes it go into wild automatically, could you not just pull the fuse and install a toggle switch across the fused location?
#43
#44
I need some splainin' here. The M2W is a remote control for the NPP optional factory exhasust? Is that right? And, it allows you to proportionally open the valves to get more or less noise? I just installed a set of QTP low profile cutouts with wireless remote on my '09 and it provides me the same capability. My car doesn't have the NPP option and I priced out the B&B fusion at around $2,200 installed. The QTPs were $800 installed (turnkey) and they sound great. The additional set of cats, that Chevy recalled the car to install, provide the proper amount of muffling ahead of the cutouts to prevent the "open header" sound that I get from my '69 Mustang, where the cutouts are installed at the back of the collectors. I run with the cutouts just barely cracked to give it a little more aggressive sound. There's no battery issue with leaving them full on or full off or partially on. I love it because it allows me to just press a button and return to the stock "Toyota Camry" sound, ending interest from the local constabulary.
#45
that is exactly what it is. You could go get an old school keyless entry and a relay and do the same thing. However it is small and is pretty much plug and play. I am going to just run a switch to mine as my remote is lost
#47
Simple is as simple does. A switch will do the trick but is no where as easy or cool as the Sunset Orange wireless set up. It is as simple as plug and play gets except for a little bit of wire routing and it uses one of the home link buttons on your sun visor if so equipped. Yes it's more money but there is no drilling or extra fuse holders required to provide a series circuit. Each to his/her own but for me for 4 years it has been music to my ears at the simple push of a button.
#48
My friend and I both purchased 2011 Grand Sport verts last June, and I installed the M2W on both cars. I have my M2W on all the time, and I drive the car almost daily with no problems. My friend drives his only once every 7 to 10 days. Last week his battery was dead, and he had the car transported to the local Chevy dealer. They kept it two days with the conclusion that the battery was drained down by the M2W, so he had them take it off. I'm waiting to see if he has any further battery problems.
Unbelievable, I bet they sold him a new battery also.
#51
Mild to Wild to Dead Battery?
Just wondering if anyone else has had a similar experience?
#52
Rather than doing the 'collar' thing, I installed clips (speed nuts) over the butterflies which prevents them from closing all the way. The clips hold them open approx 1/8". 'Mild' now has a little more hummmm..... but not noticeable on the highway. I also have the M to W dead pedal switch which is much more user friendly than the fob. Absolutely love this setup.
Guyzer7 (03-31-2019)
#53
Mild to Wild
I ordered and installed the MTW device around 7 months ago and It worked great. Then a few weeks ago I went out to go for a ride and dead battery. I looked everywhere to see if lights had been left on somewhere or what could be the cause. Charged the battery back up and took it to Auto Zone for a check. The guy put his battery tester on it and said the battery was fine. Then after two days in the garage went to start the car and same thing...dead! After reading some posts on this forum and others some suggested the MTW. Since that had been the only change made to the car, I disco'd the MTW and no more problems. Not sure if I want to do the no drain optional installation so might opt for the foot switch option that uses no power. BTW, the battery was a Delco about 2 years old.
Jim
Hans D (01-29-2017)
#54
Bought one several years ago and had it on my 2009 Base Convertible. Moved it over to my 2011 GS Convertible when the other one was totaled out in February 2015. Never had any problems with it in either vehicle. I leave mine open about 95 percent of the time if not more.
Hans D (01-29-2017)
#55
Speed nut clip
Appreciate members like you that take the time to respond and share great mod info.
Jim
Hans D (01-29-2017)
#56
No screw required. Just slip the clip over the butterfly. Super easy and just as effective as the collar.
#57
Bought one from a forum member and installed it last month. No problem with the battery so far. I seem to recall the instructions have a way to install that will avoid the drain on the battery. Go to their web site and there are directions.. I will also look on my work table to see if I have the instruction sheet.
Jim
Jim
#58
#59
Speed Nut clip idea
Appreciate your input/pictures and unique & simple solution.
Regards,
JB
#60
IMO, the sound is much better than the stock fully closed position. The car has a noticeably louder and beautiful hum as I row through the gears (6spd m). Not harsh at all and no drone at highway speed. Enjoy!!
