So as I was driving tonight, I just held off shifting into 2nd until I was going around 22 to 24 MPH. It worked like a dream. No issues with sliding into 2nd gear. My problem has been solved.
I agree this 1st to 4th feature is a bit odd. Shame on me for not completely understanding the workings of the tranny. Shame on GM for installing a fuel saving option in a freakin race car. WTF? They should save crap like that for the Cruze or those other economy cars they are turning out now.
There has to be a reason those $25 harnesses exist that you have to plug in to the transmission, otherwise why wouldn't everyone do the fuse thing?
I've had the fuse fix on mine for a year now. My C6 is a daily driver and I haven't noticed any drawbacks to using this at all. My old C5, I used the CAGS harness and it seemed to work just the same way. So, not really sure why some are going that route instead.
I haven't been driving my GS long enough to really see how the CAGS affects fuel economy, but it makes sense. If you are under low throttle and attempting to shift into second at low speed, then you don't really need the mechanical advantage of a low gear to get you moving down the road. You can shift into a higher gear and keep lower engine RPMs and still get up to speed pretty well. I have followed the CAGs prompts whenever I see them and not held up traffic. I understand the desire to disable this feature for track use, but I am going to assume the engineers at GM know a little more about the 'vette than I do, and try to use it the way they designed it.
But, after reading your post, and the subsequent responses, I have been holding onto 1st gear a little longer and it seems to shift more smoothly. I haven't had a standard for my daily driver in almost ten years and I am having to get the feel for the clutch again.
Unless I'm starting out uphill, I usually start out in 2nd. Avoids the issue. If I start out in 1st, I make sure I'm going fast enough to avoid the override to 4th.
