Dumb Question
Old Jul 4, 2012 | 11:07 AM
CPTAHAB's Avatar
CPTAHAB
Default Dumb Question
Buying a new house...when I enter the driveway, no scrape...when I back out, I scrape...WTF? Any maneuvering tips???
Old Jul 4, 2012 | 11:13 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Curious you scrape when backing out and not when pulling-in. Try turning the car on an angle when backing out to see if that helps. Good luck!
Old Jul 4, 2012 | 11:15 AM
CPTAHAB's Avatar
CPTAHAB
Thanks man!
Old Jul 4, 2012 | 11:41 AM
not08crmanymore's Avatar
not08crmanymore
I have the same issue so i turn the wheel when backing out and sometimes I catch it right and no scrape.At any rate,the only thing scraping is the black plastic thing under there that is supposed to scrape to protect the car anyway!It's a cheap replacement part if it ever needs replacing.
Old Jul 4, 2012 | 11:42 AM
EVRose's Avatar
EVRose
I scrape backing out only too. Has happened in two different driveways. It happens no matter what kind of angle I try and I've tried them all. Oh well, it's no big deal really. I just hate when it happens and any neighbors that happen to be out are staring at me like I'm destroying something on the car.
Old Jul 4, 2012 | 11:47 AM
CPTAHAB's Avatar
CPTAHAB
Ha!! Exactly!! The old ladies walking their poodles think I'm breaking something. Thanks again fellas!
Old Jul 4, 2012 | 11:52 AM
Gman in NC's Avatar
Gman in NC
Yea, I have a my C6 and a Jeep Wrangler too. They both do that. Can get confusing for sure.
Old Jul 4, 2012 | 12:33 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
Same thing happens in my parents driveway. I don't worry about it.
Old Jul 4, 2012 | 12:43 PM
Batman 357's Avatar
Batman 357
Same thing happens at my daughters house. Their driveway is pretty flat but it scrapes due to the crown of the road.
rcallen484's Avatar
rcallen484
There are no dumb questions, just dumb people.
Old Jul 4, 2012 | 12:48 PM
Nice Ride's Avatar
Nice Ride
A good concrete or black top guy could likely add a slight rise to the drive way ramp low point that would likely solve the problem.
Old Jul 4, 2012 | 12:53 PM
*Ragin Cajun*'s Avatar
*Ragin Cajun*
I come in perpendicular to my driveway then turn hard to start driving up. Backing up is the same way. I never scrape and my driveway is fairly high.
Old Jul 4, 2012 | 12:54 PM
LPT2011's Avatar
LPT2011
Wow ... this is an easy one
The Corvette has an air dam that actually comes in 3 pieces. That is the plastic piece you see under the front between the tires. The air dam is designed to bend to the rear as you drive the car. When you pull into a driveway it simply bends so you don't hear the scraping. When you back our of the driveway this causes the air dam to "rub against the grain" ... so you hear the scraping.
There are 2 plastic pins (one on each side) that connect the 2 side pieces with the main front piece. The pins are cheap and easy to replace - however unless you fix the driveway you will always scrape and be breaking the pins.
Old Jul 4, 2012 | 04:21 PM
Seadawg's Avatar
Seadawg
The front will usually be slightly lower when you are in reverse, if you are under any kind of power.
Old Jul 4, 2012 | 09:16 PM
MThomas's Avatar
MThomas
just a guess...but I believe the air dam under the front end will bend backwards when pulling in. However when you (we) back out of the driveways it does not bend forward. Therefore you hear the scrap sound. Just guessing!!
Old Jul 4, 2012 | 11:38 PM
ThrottleUp's Avatar
ThrottleUp
Houston Events Coordinator
Driving into the driveway I rarely ever scrape either. But I have the same problem backing-out and here's my theory about it and how I avoid the "reverse" scrape (most of the time).
My thinking is when I approach there is no springing of the suspension going in (at that low speed the car is steady-state). The suspension gets into the act when the front tires begin to roll up the driveway but by then (due to the ovehang) they have pushed the "scraper" up enough to avoid the scraping noise.
In reverse however, the suspension gets into the act and the car "jiggles" ever so slightly (it helps to lessen the problem to set suspension on "Sport" not "Tour") and as the tires drop off into the street there is a bounce that makes the scraping part "scrape".
Anyway that is how I visualize the thing.
Like others have said it helps to pull out very slowly and turn nearly full lock so the car is as close to parallel with the driveway as the width of your driveway will permit. At that acute angle I rarely never have a problem scraping.
It helps if you're thin like me I guess and if you have a passanger or carrying too much weight then this wont work.
My homeowner's association won't let me alter anything but that's another story...
Old Jul 4, 2012 | 11:42 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Your Jeep scrapes, what kind of entrance do you have to your driveway?
To Dumb Question
Old Jul 5, 2012 | 12:18 AM
TKgs2010's Avatar
TKgs2010
Same problem here, I found that backing out at a sharper angle pretty much eliminates the scraping issue. The only part that scrapes is the replaceable air dam under the front end anyway, about $100 to replace if I need to.
Old Jul 5, 2012 | 12:20 AM
Jimmy W1's Avatar
Jimmy W1
I always slow down and
pull into driveways, cross RR tracks, etc. at a 45 degree angle. That might help.
Old Jul 5, 2012 | 08:32 AM
TLS_Addict's Avatar
TLS_Addict
Any unusual breeding?
