I know this will probably be a dumb question and I think I know the answer. I am getting three codes..
P0151 low voltage bank 2
P0174 fuel trim lean bank 2
P0300 engine misfire
I'm pretty sure it's just the O2 sensor cause I already changed the plugs and wires.
Btw Its a 07 c6
I didn't do anything to the front. I have thought about cleaning the maf. But I also think the wire on the o2 sensor could have burnt since the wires go right next to the long tubes
Btw Its a 07 c6
Lean bank codes suck. After doing the obvious things mentioned already, if it doesn't clear-up I would just get the car scanned with a tech II or HPT rather than start throwing parts at it (like O2 sensors etc). Several good performance shops is in your neck of the woods can scan/diagnose it quick.
well i cleared the codes. The lean code went away but now im getting four different 02 sensor codes. low voltage, high voltage, circuit insufficient, and heater performance. all bank 2 sensor 1
