Help!!!....dull paint after rubbing compound
Had to use some rubbing compound to get a tar like substance off my front bumper and now the paint in that area is slightly dull. What can i use to restore the shine? Read on other message boards to use a polish which contains abrasives, but not sure which one. Any help would be appreciated.
David
David
A finishing polish should do the trick.
If you are getting your products over the counter try Meguiars Ultimate Polish. Then make sure to clean it before applying a wax or sealant because of the oils the polishes leave behind.
It all depends on how harsh of rubbing compound you used. But, use a good wax over top of it. If you have a buffer that will help bring the shine back while using the wax.
Actually the rubbing compound is more abrasive. In essence you have sanded your paint. As long as you have not cut the clear coat, you can just polish the finish back by hand. Just use something like SwirlX and a coat of wax, you will be fine.
why don't you post this in the car care section - include a picture of the area in question.
St. Jude Donor '13
Meguiars #205 with a dual action polisher should bring the shine back. It's a long shot that hand polishing will bring it back. If you don't have the tools, I would suggest stopping by a local detail shop in your area and ask about buffing up that particular spot. Best of luck to you!
David
David
By hand!
Start with a mix then move to straight polish compound.
Wax when you get the finish back.
isopropyl alcohol is the best thing to use to get tar off of paint. then wax it.
