added the Z06 front conversion and a set of Weld wheels
Old 08-23-2012, 09:44 PM
turbotuner20v
turbotuner20v's Avatar
Default added the Z06 front conversion and a set of Weld wheels
I had been running the rear wide body for a while, and decided to bite the bullet and do the OEM front conversion as well. Along with the new fenders I picked up some new wheels to fit all 4 corners and hopefully help with traction as I turn things up.
*Edit*
Added photos from this weekend below:
Old 08-23-2012, 09:51 PM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Looks good more pictures please
Old 08-23-2012, 09:54 PM
turbotuner20v
UPS truck is bringing my front inner fender liners tomorrow so I can get it fully buttoned up, then I'll snap some more pics
I'm debating attaching the front lip or not... I actually like how it looks now.
Jazc9
Jazc9's Avatar
Car looks great. I recently purchased set of Z06 wheels, considering the wide body conversion. How complicated was the swap
Old 08-23-2012, 09:59 PM
turbotuner20v
Not bad, there's a great DIY (http://www.myvettesite.com/files/widebodyguide.pdf)
Here it was a few days ago:
Old 08-23-2012, 10:34 PM
ncvette_1FUNRIDE
ncvette_1FUNRIDE's Avatar
2015 C6 of the Year Finalist
The car looks great!
Is that your Maxjax lift? How do you like it? Does your car feel really stable on it?
I have had one sitting in my garage forever and I hope to get it installed this fall.
Also who installed it?
Old 08-23-2012, 10:42 PM
jpee
jpee's Avatar
What color is your car.. you had 2009 in your info, but it sure looks like LMB & that color was stopped in 2007 ? I could be wrong, but I'm looking at the photo in post #1 That looks a lot more like LMB than the blue that came out on 2008 ?
Whatever blue it is it looks GREAT ! Also can you please send me more Info on the exact wheels, & tires you have... they are the "BEST" set up I have seen IMO ..
I'm into drag racing, and your rear wheels look great nice big sidewalls... Do the wheels fit right on or do you need spacers, or have to do any mods... I don't want anything larger than 18" Front and 19" rear.. (prefer 18" rear also)
Thanks. you can PM or E mail me....
Old 08-23-2012, 10:44 PM
turbotuner20v
Yup, I like it a lot. You may need wood planks to pull up on if you're lowered, the arms don't slide under the car with the pads installed. The car feels really stable when it is at one of the 'lock bar' heights. I've been cranking on bolts and got the car rocking a bit and it never came close to shifting or anything bad. The only complaint I have is the hydraulics. They leak a bit and they don't raise 100% evenly. I've loved using it for my brakes and headers, it should really help with the motor swap and clutch replacement... I'll probably just drop the whole driveline and raise the body off it. I installed it myself.
Old 08-23-2012, 10:47 PM
turbotuner20v
It's a 2009 Jetstream Blue. This color is pretty interesting, just a fraction of an angle different and the color shifts quite a bit, also depends a lot on lighting and the sun was setting in these photos. Thanks
Old 08-23-2012, 10:51 PM
turbotuner20v
I'll just post here incase anyone else is curious. They're Weld RST wheels... 17x11 rear & 18x6 front. The rears are running M&H Racemaster 325/45-17 drag radials and the fronts are running Sumitomo HTR Z III 225/45-18 street tires. They bolt right on, no spacers.
They can do an 18" rear wheel too, I almost went with that instead of the 17".
Here's my old setup with 19" front/19" rear ZR1 wheels w/ NT05R's
Old 08-23-2012, 10:57 PM
jpee
jpee's Avatar
Thank Youuuuuuuu.....I like your set up with the 17" rear.. I can get a better drag tire for 17" wheels & they look AWESOME on your car !!!
PS don't park it anywhere in Westchester NY... LOL
Old 08-23-2012, 11:02 PM
jpee
jpee's Avatar
I'm sorry for being a "dork" but when you had the 17' on the rear and 18" on the front, with the tires you used did you get any DIC warning about tires size etc... I'm using 18" in the rear now with Nitto DR 315/35x18" with stock size fronts and have had no problems....
Old 08-23-2012, 11:10 PM
turbotuner20v
Nothing has popped up so far. I haven't driven it too far though... basically around the block to settle the suspension to check the wheel fitment, then tomorrow I'm installing my z06 inner fender liners and really taking it out for a drive.
Old 08-24-2012, 11:01 AM
2slow95vert
2slow95vert's Avatar
Your car is gorgeous. More pics of the wheels please. Will the rears clear GS/ Z06 brakes?
Old 08-24-2012, 11:03 AM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Nice ride
Old 08-24-2012, 11:08 AM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
welcome to the fat club, turned out great
David
Old 08-24-2012, 11:22 AM
turbotuner20v
I'm heading to a car meet/show tonight where I'll see a few of my photog friends, I'll try to get them to snap a few real pictures... my cell phone photos at the mall around the corner leave lots to be desired, lol.
This setup is an off the shelf option for the C6 Z06 from Weld, so they will fit Z06 brakes. They also have a set for the base C6 too (my order was originally z06 rear, c6 front, but then I bought my fenders and had to change them mid-build)
Here's another pic I have though:
To added the Z06 front conversion and a set of Weld wheels
Old 08-25-2012, 01:13 PM
turbotuner20v
I have some 'real' pictures now...
Old 08-25-2012, 02:32 PM
Zo6 Lover
Zo6 Lover's Avatar
good looking!! what camera u used?
Old 08-25-2012, 02:34 PM
turbotuner20v
I used an HTC EVO 4G... I'm not sure what the photog from the friday event used.
Quick Reply: added the Z06 front conversion and a set of Weld wheels
