how to remove the 2 Targa top holders in trunk
how to remove the 2 Targa top holders in trunk. I mean the 2 small holders that are connected to the rear of the cargo area that holds the targa top.
Received 2,047 Likes
St. Jude Donor '13
The "hooks" to store the front of your targa top, have a plastic trim cover that just slips off if you pull up hard. But the hook itself is firmly mounted, IIRC it has a couple of torx head bolts that go down into the tub or perhaps even deeper.
No ideas about the rear clips.
Yes, pull carpet back and there are two bolts on each one. Remove those and they come out. Do not pull on visible plastic part that top snaps onto or you will rip them off the rubber mount and they are ruined. Very easy, takes about 5 min to do right.
Great Thanks to all
