Harmonic balancer failure poll - Page 13 - CorvetteForum - Chevrolet Corvette Forum Discussion
View Poll Results: Harmonic balancer failure poll
I have not experienced a problem
536
64.81%
I think I have a problem now
70
8.46%
I have replaced it once
132
15.96%
I have replaced it twice or more
22
2.66%
I have replaced it, but decided not to use a GM part and went for an aftermarket unit
67
8.10%
Voters: 827. You may not vote on this poll
Old 11-28-2014, 09:22 PM
  #241
Mad*Max
CF Senior Member
Mad*Max's Avatar
Originally Posted by COMMANDER2OOO View Post
please forgive my ignorance, but what is nccc?
http://www.corvettesnccc.org/Competition.html
Mad*Max is offline
Old 11-28-2014, 09:26 PM
  #242
42Chevy
It's 5 o'clock Somewhere
Support Corvetteforum!
42Chevy's Avatar
St Jude Donor '13-'14-'15
2008 42,000 miles. No issue.
42Chevy is offline
Old 11-28-2014, 10:01 PM
  #243
Rogers 07
CF Senior Member
Rogers 07's Avatar
Originally Posted by Rogers 07 View Post
07 105,000 miles, No problems yet !!!
130,000 and still no problem with the balancer, now those damn sun visor mirror covers, what pieces of **** they are, I have never used the drivers side mirror until recently, I open it and the cover just fell off, the passenger side fell off years ago.
Rogers 07 is offline
Old 11-28-2014, 10:10 PM
  #244
Robs 1988
CF Senior Member
Robs 1988's Avatar
2005 with wobble that I noticed after seeing this thread. So, can the bolt just be tightened or does it require complete replacement?
Robs 1988 is offline
  #245
COMMANDER2OOO
CF Senior Member
COMMANDER2OOO's Avatar
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
Originally Posted by Mad*Max View Post
thankyou sir
COMMANDER2OOO is offline
Old 11-28-2014, 10:17 PM
  #246
Blk 08 C6
CF Senior Member
Blk 08 C6's Avatar
I have not experienced it but replaced it with a 10% overdrive at 16k. goin FI next year.
Blk 08 C6 is offline
Old 11-28-2014, 11:36 PM
  #247
COMMANDER2OOO
CF Senior Member
ok heres mine off my 05 m6 coupe replaced at 47,000 miles as u can see the thin rubber barrier between the two metals is the prime suspect in the wobble. the rubber wears down over time an use causing it to wobble so the only fix is to replace. from what i was told this is a very cheaply made product from gm good for about 50,000 miles tightening the bolt will do nothing but make it harder to get off .
junk
Old 11-28-2014, 11:57 PM
  #248
HBsurfer
CF Senior Member
HBsurfer's Avatar
The bolt can only be torqued one time. Tightening it would not help the wobble anyway.
HBsurfer is offline
Old 11-28-2014, 11:59 PM
  #249
TerryL
CF Senior Member
TerryL's Avatar
St. Jude Donor '17
The interior quality control guys at GM should be fired. I drive an 08 base Impala from our motor pool at work and it's sun visors telescope perfectly when the sun's at my side and the mirror covers work without squeaking or breaking at the hinges. The console cover latch doesn't break either and the glovebox actually holds something more than the handbook! I use silicon spray on the mirror cover hinges and so far, on my 06 vert with 72K, they squeak a bit but haven't yet broken. The console latch broke right off. Luckily the HB is still OK. Suppose the Vette would be made a little better if it were assembled under the Cadillac division of GM?
TerryL is offline
Old 11-29-2014, 12:36 AM
  #250
Robs 1988
CF Senior Member
Robs 1988's Avatar
junk
Good to know guys, thank you. I didn't want to waste my time with that if it didn't do any good. What are people replacing them with? Surely not an OEM part.
Old 11-29-2014, 08:45 AM
  #251
COMMANDER2OOO
CF Senior Member
well i know a few guys went with an under drive to gain a few more horses. i started t do the same but my mechanic cautioned me that dew to the smaller pulley it may cause electrical problems with turning the alternator slower. these cars are temperamental enough didnt want to add any new problems. so i went with this.
its advertised as spin tested at 12000 rpm an since my car red lines at 6 or 7000 rpm this thing should last a life time.
Old 11-29-2014, 09:03 AM
  #252
Rogers 07
CF Senior Member
Rogers 07's Avatar
Good choice ! Unless you're track racing a lot, as stated, under driven pulley's can create more problems than the slight HP increase they offer are worth.
Old 11-29-2014, 09:09 AM
  #253
Rogers 07
CF Senior Member
Rogers 07's Avatar
I suppose the performance to $$$ ratio has to be maintained by skimping here and there. As you said, those little crappy brackets and hinges shouldn't break the first time you use them. I would gladly have paid and extra Hundred bucks or so for those cheesy little items to have been better made!!
Old 11-29-2014, 03:16 PM
  #254
HBsurfer
CF Senior Member
HBsurfer's Avatar
I went to a Corvette specialist and they said this was their choice and it has also been used by a lot of people on this forum.
ATI balancer #ati-917246 $469.00
Crankshaft bolt #12557840 $ 8.25
A lot of guys on here say all balancers wobble a little and it is normal. This ATI balancer does not wobble at all and if anything does happen down the road, this unit is rebuildable.
HBsurfer is offline
Old 11-29-2014, 03:22 PM
  #255
EVRose
CF Senior Member
EVRose's Avatar
If only it were that simple.
EVRose is offline
Old 12-07-2018, 12:05 AM
  #256
PilotmyC6
Junior Member
Recently purchased a 2005 C6 LS2 with under 10,000 miles, after driving it for 200 Miles the belt started chirping. I stopped to check out the noise and noticed the belt started peeling apart. Further review revealed a loose bolt on the balancer. Itís currently at the dealer to comply with the TSB to replace the balancer and associated parts.
PilotmyC6 is offline
Old 12-07-2018, 12:54 AM
  #257
CWIC
Junior Member
CWIC's Avatar
2007 Base A6, no drivetrain mods, with 19,000 miles. Getting it replaced next week with a PowerBond, new bolt, crank seal (just because), new belts and replacing both tensioners.
CWIC is offline
Old 12-07-2018, 01:37 AM
  #258
Bruze
CF Senior Member
Bruze's Avatar
'07 base, bone stock, 35k miles, no problem (yet).
Bruze is offline
Old 12-07-2018, 08:55 AM
  #259
tsmart
CF Senior Member
tsmart's Avatar
10 base. 19000 miles. Replaced. Numbers illustrate 22% failure, that is huge.
tsmart is offline
Old 12-07-2018, 10:53 AM
  #260
ram01
CF Member
ram01's Avatar
Replaced at 64000 on 2005.
ram01 is offline
Quick Reply: Harmonic balancer failure poll
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
