Old 02-19-2015, 07:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
DIY Exhaust Enhancer Plate install with Pics
Old 02-24-2013, 08:25 PM
JKbride
Support Corvetteforum!
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Default DIY Exhaust Enhancer Plate install with Pics
Below are the DIY instructions on how to install an exhaust enhancer plate.
It is very simple to install and takes all of 15 minutes to do For those who may not be handy with a wrench this is a beginners level DIY mod, and you will take pride after you install it There must be 20 styles of plates from various vendors on CF...pick the one that is right for you and have fun installing it...its very easy.
Note: Some exhaust enhancer plates will not work with NPP exhaust systems, so check before you buy.
Before
After
TOOLS
All you need is a 13mm socket with an extension
The Process
Crawl under your car from the rear and look up between the exhaust and you will see where the rear exhaust hanger is mounted. This is what you will see …….
Loosen the nuts (don’t remove) with your 13mm socket.
The plate has horizontal and vertical oriented slots. Slide the horizontal slot under the nut you loosened then rotate the vertical slot onto the opposite hanger bolt and secure. (hold in place with one hand till the nuts are snugged up or it will fall)
Here it is in place (apologies for the blurry photo).
Set back and enjoy your handy work!
Hope this helps someone!
John (aka JKbride)
Old 02-24-2013, 08:31 PM
okie08vette
okie08vette's Avatar
Nice post and I am sure it will help lots of folks.
Old 02-24-2013, 08:34 PM
alyupe11
alyupe11's Avatar
Looks good
Old 02-24-2013, 08:37 PM
spdkilz911
spdkilz911's Avatar
They will work with the NPP system depending on the plate. Mine came with two holes and no slots. I "customized" it so it could be installed without taking it all apart.
Old 02-24-2013, 08:40 PM
JKbride
JKbride's Avatar
Thank you, I do not have a NPP and was not sure....I have amended my note about NPP's
Old 02-24-2013, 08:53 PM
spdkilz911
spdkilz911's Avatar
Not sure if it just needs to be thinner or what? I know it was a question that was asked when I ordered mine.
Old 02-24-2013, 10:08 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Originally Posted by alyupe11
Looks good
Old 02-24-2013, 11:12 PM
Johnson 92
Johnson 92's Avatar
C5 of the Month 6/13
Looks great!!
Old 02-25-2013, 10:32 AM
Biggie G
Biggie G's Avatar
nice!
do you have a stock defuser?
where did you get the plate?
thanks
Old 02-25-2013, 10:53 AM
BenDiem
BenDiem's Avatar
OP,
Thanks for the post!
I tried to mount mine last winter, with no luck. Since then, I forgot all about it. The mounting instructions provided by the vendor were difficult to read/comprehend due to the poor photocopy image. It was too dark. I should be able to master this mounting, now...
Appreach,
B
Old 02-28-2013, 11:06 PM
JKbride
JKbride's Avatar
Originally Posted by Biggie G
nice!
thanks
Yes, stock defuser. I purchased from CF supporting vendor CorvetteMods.
You can look here http://www.corvettemods.com/Exhaust-...tes_c_159.html
I think other supporting vendors have these as well.
Old 02-28-2013, 11:08 PM
JKbride
JKbride's Avatar
Originally Posted by BenDiem
OP,
Appreach,
B
Glad I could help post a pic when you install it
Old 03-01-2013, 12:18 AM
0corvettemods1
Former Vendor
corvettemods1's Avatar
Great writeup!
FYI...works on all stock and npp kits
Old 03-01-2013, 02:39 AM
Natas 07
Natas 07's Avatar
Leave to John! Thanks buddy!
Old 03-01-2013, 07:37 AM
SK360
SK360's Avatar
Never understood these.... Isn't there a corvette logo 3 feel above it?
Old 03-01-2013, 08:17 AM
crAzy
crAzy's Avatar
Much easier for you. It took me damn near 45 min to install one on my Z. Could barely get my hands in there and I had to use an open ended wrench. Now i lost one of those bolts and im pissed. Guess i didn't tighten it enough
Old 03-01-2013, 09:04 AM
NCorvette
NCorvette's Avatar
Terrible. Either go to quad exhaust or center them next to each other
To DIY Exhaust Enhancer Plate install with Pics
Old 03-01-2013, 09:33 AM
ZR1Cat
ZR1Cat's Avatar
Originally Posted by corvettemods1
Great writeup!
I just checked out your website and saw your advisory: "Tech Note: Will not fit Z06/ZR1's due to bolt hanger locations."
That bummed me out. I was thinking about buying the Centennial Edtion version for my ZR1. But no workie on my stock NPP.
Old 11-20-2013, 02:49 AM
bob3868
bob3868's Avatar
Thanks for great instructions to install. I did this. Here's my issue. There's a vibration noise coming from it now. When I'm driving I hear a different sound. I can't get the bolts any tighter. Anyone have something like this?
Thanks.
Old 11-20-2013, 06:50 AM
VET4LES
VET4LES's Avatar
Good job.
Quick Reply: DIY Exhaust Enhancer Plate install with Pics
