Differential cooler (How do I know) need help
This weekend I plan to change my differential fluid. After reading several post, I been warned to check for a differential cooler before changing the fluid because the procedure is different if I have one.
Can someone send me a picture of what the differential cooler looks like and the location to find it so I can check to see if I have one.
No leaks on garage floor, boots not wet.
I did see splash marks on the underbody of car, driver side near rear muffler over-axle-pipe above differential boot. Splash did not look fresh but was slightly geasy. I cleaned area to see if splash re-appear. This is why I am changing the fluid to make sure its not low.
Dexron LS Gear Oil 75w-90 (3 qts) #88862624 Sythetic.
Need pictures to make sure I do not have a differential cooler
2005 Corvette, 88,000 miles
redo.. sorry.. lol
ok... so this is a shot in the dark. i have little clue if this is the the cooler, but it sorta says it is. see item #16.. then see link for this pic that gives it a description
http://parts.nalleygmc.com/showAssem...hString=cooler
Z06s have differential coolers
here is the change method for a Z06.. note drain is a tube/fitting instead of a plug..
http://forums.corvetteforum.com/c6-z...-specific.html
above link's pics match the instructions when c6 has cooler (about half way down)..
http://www.southerncarparts.com/corv...nge-pm-43.html
so... tell me if i'm all wrong, i admit i just looked up on the web and found this. if i'm wrong will delete to keep from confusing anyone else.. lol
If it's a non Z51 base 05, you will need a cut off allen wrench to get the drain plug out. It is located partially over the rear spring. It is a pain to get at it, so be patient. Use the latest diff fluid from GM. I don't remember the part # but the one you listed doesn't seem right. I thought it ended in xxxxxxx28. Could be wrong.
Received 2,887 Likes
Don't forget the friction modifier unless you want the clunking noise we are so prone to having.
European export models also have the diff cooler as they are expected to be on ze autobahn cruising at high speeds. Dexron LS is the new fluid and it already has the friction modifier in it unlike most rear gear oil. Get your credit card ready as it is very expensive stuff.
