chrome alternator & Bracket installation
Old 03-29-2013, 06:53 PM
ydeer
Support Corvetteforum!
ydeer's Avatar
Default chrome alternator & Bracket installation
Need help with the installation of a new chrome alternator & Bracket. If anyone has done this install your help is well appreciated. It seems that in order to remove the old bracket you have to either remove or loosen the power steering pump so you can remove one of the bolts on the bracket. I could use input from anyone who has done this conversion and what precedure that they used. Thanks in advance
Old 03-29-2013, 07:25 PM
Seadawg
Seadawg's Avatar
It depend on model of vette, so more info is needed, I've seen a post about this in the tech forum I believe, I would search there too.
Old 03-29-2013, 07:28 PM
RicK T
RicK T's Avatar
This probably isn't as detailed as you need but check it, might be enough:
http://forums.corvetteforum.com/c6-t...t-off-car.html
Old 03-29-2013, 10:22 PM
ydeer
ydeer's Avatar
Thanks for the help. Gives me a little better insight of what i have to do. If anyone has any other help on this issue please post it. Thanks to all
Old 03-30-2013, 09:09 AM
ydeer
ydeer's Avatar
ttt
Old 03-30-2013, 10:06 PM
ydeer
ydeer's Avatar
ttt
Old 03-31-2013, 09:09 AM
Swiftrider08
Swiftrider08's Avatar
Yep, you need to get all the bolts out of the ps pump. Not bad, just aggrevating.
To chrome alternator & Bracket installation
Quick Reply: chrome alternator & Bracket installation
