Help With passenger side fuse box please?
I just picked up my 05 Vert and the lighter does not work so I looked in the manual and it loosely describes the location of the fuse box that holds the cig lighter fuse? I pulled the carpet back and found the fuse box diagram and fuse box but it indicates the cig lighter fuse to be on the right side of the fuse panel, I can not find the section of the panel that holds not only the cig fuse but many others? It looks like it may be inside a black plastic box but there is a large BLUE right angle harness in which the wires to it are hanging in front of this black box? I do NOT want to remove the blue connector unless it is necessary to do so to check the cig fuse? I'm not sure I would even know how to disconnect it?
Thank you for any help!
I just tried to pull the cover and it won't budge, it is pinned tight to the blue module above it? I will either have to take it to the dealer or unplug the blue connector, not knowing what that blue connector/harness is for I am very afraid to do that?
Cruising
my cig fuse blows everytime I take out the console. the black plastic cover is retained by a couple of clips on either side if I recall. It will come off without disconnecting everything although it's rather difficult to get to I admit.
Cruising
the fuse box clips may be on top and bottom as well... it's been awhile since I've removed the cover. I assure you though, that it will come off without disconnecting anything.
