Window tint ?
Old May 22, 2013 | 07:36 PM
jumm's Avatar
jumm
Default Window tint ?
Local installer wants to put vinyl over dot-matrix and tint below that. Is this correct? Thanks in advance!
Old May 22, 2013 | 07:41 PM
EVRose's Avatar
EVRose
I have heard of that being done. The vinyl covers the dots better and easier than tint.
Old May 22, 2013 | 07:55 PM
phileaglesfan's Avatar
phileaglesfan
My installer covered it with tint and did a fantastic job. I heard of the vinyl before. Coupe window is a real pain to tint so make sure your installer has done them before.
Old May 22, 2013 | 07:58 PM
Homer3D's Avatar
Homer3D
Both my 2005 and 2013 have vinyl covering the dotted area.
Old May 22, 2013 | 08:17 PM
spdkilz911's Avatar
spdkilz911
Very common practice. No worries with the vinyl.
Old May 22, 2013 | 08:28 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Old May 22, 2013 | 08:53 PM
Ozzy12's Avatar
Ozzy12
Personally, I think vinyl is for someone who isn't as confident in their product or their expertise. Mine is done in all tint and its perfect. Just took some time and finesse.
Old May 22, 2013 | 09:03 PM
EBvette02's Avatar
EBvette02
They did my window with just tint and it looks like crap at the dots.
Old May 22, 2013 | 09:04 PM
05vetteowner's Avatar
05vetteowner
There is also a product that makes tint bond better to the dot-matrix. My installer used it and said it helps a lot. Can't think of the name of it off the top of my head though. Tint all the way and it looks great
Old May 22, 2013 | 09:26 PM
JLB768's Avatar
JLB768
On my 2nd and 3rd C6's, I had vinyl put over the dot matrix, for my own peace of mind, #1 eventually looked like crap. The vinyl looks great, and you can't see it from the rearview mirror anyway.
Old May 22, 2013 | 10:09 PM
jumm's Avatar
jumm
Thanks!
Old May 22, 2013 | 11:12 PM
Cherokee Nation's Avatar
Cherokee Nation
Post a picture..I've never seen C6 that is fully covered with tint only.
Old May 22, 2013 | 11:33 PM
Cherokee Nation
Old May 23, 2013 | 08:27 AM
Ozzy12's Avatar
Ozzy12
Here you go. This is 15% Llumar Ceramic all the way around with Airblue on the windshield.
The trick my guy said is that you have to let the tint dry out enough that you can get around each dot and not have bubbles. Applied it partially and then hung the rest off overnight to dry, then applied the tint to the dot areas.
Old May 23, 2013 | 08:42 AM
cpmatthew's Avatar
cpmatthew
A lot of people have the vinyl over the dots. Others have tint over the whole window. Vinyl seems to be the safer option. If the installer doesn't get it right, the tint won't stick to the area with the dot matrix and you will get bubbles.
Old May 23, 2013 | 09:10 AM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
Specifically request vinyl on all my cars now after my experience with what was originally a perfect tint job on my Z28 start separating over the dots after a couple hot summers. Vinyl never caused a problem. Guess it all depends on what you like. For me, I prefer the vinyl because I know it won't be problematic later. YMMV.
Old May 23, 2013 | 10:14 AM
Cherokee Nation
The back window does not look like the top dots are covered?? Maybe it's my eyes. Beautiful Vette you have..
To Window tint ?
Old May 23, 2013 | 10:19 AM
Cherokee Nation
I paid $ 250.00 for my tint,I'll take it back & have the vinyl put on.The best way to go from reading these posts.....
Old May 23, 2013 | 10:34 AM
veloz's Avatar
veloz
i tried the vinyl on the dots and didn't help much. still looked bad...helped some but you still see them...i m thinking about using the lens paint to do these areas - the paint will fill all areas around the dots unlike the film that will trap air and wont adhere correctly...anybody ever done that?
Old May 23, 2013 | 03:51 PM
Cherokee Nation
I've heard of guys doing that,but never seen it in person.
