Thoughts on removing the rubber/plastic lip under nose?
#61
My new driveway has a bump that will not clear the 2.5in clearance of the 3 piece front plastic lip guard. There is a 6-10 inch 45 degree incline and then flat driveway.
I can hear it scraping the lip and distorting it to the point it seperates from the plastic button holding it to other pieces. I have tried coming in at all angles.
What are my options?
-Remove entire plastic lip guard
-Back in?
-do they make a higher lip guard?
Is it a DIY pop off or does dealer have to do it.
-Back in?
But they are super easy to trim, and you can easily do it with a pair of tin snips that you can get at the hardware store. Even just an inch trimmed makes a world of difference.
I try not to remove them entirely, as they are there to aid in cooling, and to help cut down under car wind noise.
Thanks,
Mitch
