New TSB for Oil Pump problem on 2013 Could Cause Engine Failure.
Old 09-24-2013, 08:55 PM
RLK
RLK's Avatar
Default New TSB for Oil Pump problem on 2013 Could Cause Engine Failure.
Some kind of pressure relief valve within the pump sticks/fails causing low or no oil pressure how nice. # PIP 4158F
Old 09-24-2013, 10:08 PM
LMB-C6
LMB-C6's Avatar
Hmmm, seems to affect '07 to '13. Anyone have the details?
LINK
Old 09-24-2013, 10:16 PM
RicK T
RicK T's Avatar
One discussion of several:
http://forums.corvetteforum.com/c6-t...-pressure.html
TSB (PIP4158C): Note it was "C" back in 2011.
http://forums.corvetteforum.com/1578265354-post5.html
Old 09-24-2013, 10:55 PM
LMB-C6
LMB-C6's Avatar
Old 09-25-2013, 12:48 AM
DAFFYDRUNK
DAFFYDRUNK's Avatar
As far as I've read, this has been an ongoing problem since the first LS1s. I think what can happen is debris gets caught in the pressure relief valve on the oil pump and it can't close so you lose oil pressure to the rest of the motor. More prone to happen, for example, if you recently did a cam swap.
Old 09-25-2013, 12:56 AM
ProfessorDeath
ProfessorDeath's Avatar
St. Jude Donor '13-'14
Had to replace my oil pump in my 1998 Z28 a couple times. Never really figured out why it failed. Perhaps I've just learned.
Old 10-08-2013, 11:38 AM
RLK
RLK's Avatar
Bump
Old 11-25-2013, 04:18 PM
Red Lightening
Red Lightening's Avatar
Originally Posted by RLK
Bump
Bump
To New TSB for Oil Pump problem on 2013 Could Cause Engine Failure.
Quick Reply: New TSB for Oil Pump problem on 2013 Could Cause Engine Failure.
