Coolant change question
Old Nov 13, 2013 | 06:02 PM
  #61
Red08's Avatar
Red08
I bought Prestone Dexcool at Walmart.
Old Nov 13, 2013 | 06:37 PM
  #62
LMB-C6's Avatar
LMB-C6
Originally Posted by RoadkingC6
I plan on draining my antifreeze, mine is a2005 and im sure it hasn't been done yet, I was thinking I would change the t-stat at this time also, not having any problems just thought now would be a good time to put a new one in, any thoughts? is Dexcool available at most Aotomotive stores or is something you have to get at a dealer.
Dex-Cool is made by many different manufacturers. Prestone is probably the easiest to find, but Havoline, Zerex, and parts store house brands are also out there.
I would not replace the t-stat as part of the coolant flush - if it isn't giving you trouble leave it alone.
Old Nov 15, 2013 | 02:18 AM
  #63
LS WON's Avatar
LS WON
Had waterpump changed and dealership told me that waterpump comes with new thermostat.
Old Nov 15, 2013 | 04:31 AM
  #64
Rebel 1's Avatar
Rebel 1
Originally Posted by LS WON
After I had waterpump with thermostat replaced and new Dexcool via dealership at 48,000 miles (Used Amsoil anti-freeze before this) my temp went from 192 to 196. So now it runs a few degrees hotter.
Your stock thermostat is/was 187*.
Sounds like your new water pump came with a 195* stat with it.
Stats have the opening temps inscribed on them.
I always test a stat in a pot of water bringing it to a boil gradually. I watch the temp and note when it Starts to open using a meat thermometer.
Old Nov 15, 2013 | 10:51 AM
  #65
LS WON's Avatar
LS WON
I don't know why they would put in something different since they are the dealership and usually replace with part of same rating unless there is some improvement on new part.
Thus far car runs mostly in the 196-198. Sometimes it still goes down to 192.
Old Nov 16, 2013 | 12:00 AM
  #66
HOXXOH's Avatar
HOXXOH
Since the temp sensor is in the head on the opposite side of the t-stat, it's normal to see DIC readings about 10* higher than the t-stat.
Old Nov 16, 2013 | 01:47 AM
  #67
LS WON's Avatar
LS WON
thanks for that info
Old Dec 15, 2013 | 11:28 AM
  #68
Jameskapp001@gmail's Avatar
Jameskapp001@gmail
I had my Chev truck done. They hooked it up to a machine which extracted the old fluid, flushed the system and added new fluid? I take no one has tried this or they don't like the method. My 06 has 43k miles and was thinking about getting it done in the spring.
Old Dec 15, 2013 | 12:50 PM
  #69
LMB-C6's Avatar
LMB-C6
If it's like one of the machines I've seen they actually recycle the coolant. It goes through some kind of filtering process, they replace the additive package, and then pump it back in. Unless they were using the Airlift system, which after draining the coolant it creates a vacuum in the cooling system that then sucks new coolant in.
Old Dec 16, 2013 | 03:28 PM
  #70
Jameskapp001@gmail
I checked at the garage, their machine is a vacuum set up, evacuates the coolant and pumps a cleaning solution in the evacuates it and pumps in new coolant approx 12 qts dependent on the car.
Old Dec 16, 2013 | 11:21 PM
  #71
LS WON's Avatar
LS WON
Strange dealership just put my car up in the air and drained fluid then added back anti-freeze and water and got out any air bubbles. No machine involved.
Old Dec 17, 2013 | 10:24 AM
  #72
jimmie jam's Avatar
jimmie jam
I have always questioned those "machines". I'm wondering how they can spend the money for the machine and make it back considering the minimal labor and time involved - unless their charging $150 or more for the service (not including parts). "Smoke and mirrors"? who knows.....
Old Dec 17, 2013 | 03:40 PM
  #73
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That's the official way to do it, so it must work. We did it twice on our car, with a drive in between, to get more of the old coolant out.
Also used distilled water, recommended by the lab that tested the old coolant.
Old Dec 17, 2013 | 11:57 PM
  #74
LS WON's Avatar
LS WON
I know if that is so the case it is easier to just do this yourself since this is very easy to do. I believe they make the car face forward for gravity to get most of the fluid out.
Old Dec 18, 2013 | 05:18 AM
  #75
Like dem Vettes's Avatar
Like dem Vettes
Why aren't you having the cooling system professionally flushed? My shop uses a BG coolant flush machine.
Old Dec 18, 2013 | 05:22 AM
  #76
Don-Vette's Avatar
Don-Vette
This is what I use to check coolant quality,I take my vehicles to get flushed not just drain and refill....
Old Dec 18, 2013 | 09:50 AM
  #77
Rebel 1's Avatar
Rebel 1
I always change the coolant in all my cars and trucks myself. Nobody touches my cars but me.
Pick up a couple gallons of Zerex Dexcool and several gallons of distilled water for the vette.
Drain, add water, run, drain. Do it Two times.
Add Zerex Dexcool, finish it up with distilled water. Simple.
Costs me less than $30. and know it's done right.
To Coolant change question
Old Dec 18, 2013 | 10:31 AM
  #78
NY3quartrs5-oh's Avatar
NY3quartrs5-oh
I always change the coolant in all my cars and trucks myself. Nobody touches my cars but me. Pick up a couple gallons of Zerex Dexcool and several gallons of distilled water for the vette. Drain, add water, run, drain. Do it Two times. Add Zerex Dexcool, finish it up with distilled water. Simple. Costs me less than $30. and know it's done right.
Hey rebel, what temps is your car running now? I just changed to zerex too and with a stock stat I'm running 203 steady, 208 when stopped and once in a while around 198 at highway speeds, but this is with around 40 degree cold weather... I thought I would get those numbers in the summer, not now...
Old Dec 18, 2013 | 10:54 AM
  #79
Rebel 1's Avatar
Rebel 1
203 cruising temp is higher than my car ever ran. With the stock stat it was always around 192-196* but never over.
Did your car run these temps before coolant change? Sounds like that there may be some "air" in your cooling system. Possible?
Change the stat? Some new stats are 195*. Stock is 187*.
Good luck
Old Dec 18, 2013 | 11:55 AM
  #80
NY3quartrs5-oh
that's what i thought. I did change stats from a 160 and pretty sure it is a 186 now, maybe air in system. I only changed what came out once, so maybe ill change it again to get more old out and make sure no air... thanks!!
Good luck
